Question about Keurig B60 Coffee Maker
When powering on the unit, the LCD section reads "PRIME" and will not warm up into the brewing cycle. I can't find this in the troubleshooting section of the manual and I don't know what it means or how to fix it. What should I do? This is a BRAND NEW UNIT, less than 2 weeks old.
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
I have a "prime" light and cannot brew coffee.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101-
Sep 10, 2011 | Keurig B60 Coffee Maker
It's says it's brewing and the water will go into the "warming chamber", but then it like freezes and the Keurig won't do anything. It just continues to say brewing, but nothing...
heatman101 ./.,.,
Aug 13, 2011 | Keurig Platinum B70 Coffee Maker
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
Fails to go to brewing cycle; instead flashes "prime."
Sorry to read about your problem, I hope this helps you out.
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
df
df
d
f
Dec 22, 2010 | Keurig B70 Coffee Maker
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Keurig B60 Coffee Maker Logo
41 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
