Question about Candy CNW136 Front Load Washer/Dryer
Renew washing machine front door seal
I need to fit a new door seal to my washer/drier model CMD 136-80 candy washer dryer. I found the rubber seal had come loose having torn the arm of a jacket. I am left with a thin plastic ring and dont know how to put it together or where it should be attached.
    Champion:
  • 210 Answers
That model number does'nt come up.
Posted on Aug 07, 2008
How do I replace the front door rubber gasket and seal ring?
Greg, new seal but need to know how to swap it out. Check the attached links,instruction and guides, If you want to google your make and model Washing Machine door seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Washing Machine Door Seal
How to replace washing machine door seal on Hotpoint washer
http://www.how-to-repair.com/help/how-to-replace-whirlpool-washing-machine-door-seal
How To Replace Front Load Washer Door Boot DIY
Jul 25, 2016 | Washing Machines
I would like to get some information on how to replace the door seal of a Miele Metor 4000?
Depends if washer drier or just washer...The Door boot seal is secured with two rings one on the outside of machine case the other on the inside...The tricky part is fitting the inner ring in some cases the front of the machine can be removed,greatly simplifing the job if you look on utube you will see step to step how to fit a door boot seal this may help you decide if you need an engineer to do job..Happy New year from Scotland...
Jan 01, 2011 | Miele W 4800 Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Replacing Door Seal on AQW130 Candy Washer Dryer
JUST THE SEAL IS ALL THAT IS REQUIRED AND A GOOD SET OF TOOLS AND MECHANICAL SKILLS, i AM IN THE USA SO CAN'T RECOMMEND ANY PLACE TO BUY IN UK
Jul 28, 2010 | Candy AQW130 Front Load Washer / Dryer
I just had my washer-dryer repaired by CandyHoover. They replaced the tub and drum. I put it through the half hour cycle yesterday, then today I put a couple pairs of jeans in it on the 40C cotton
hi i had the same problem clean the door seal then use some disilled malt vinegar on a 90 wash then clean your filter out then use some bleach with your washing powder on 90 wash clean your filter then you should be all good then as that worked for me
May 23, 2009 | Candy CNW136 Front Load Washer/Dryer
Candy washer dryer 1400 spin cmd 146
try taking the soap dispenser draw out a give it a thorough clean inside and on the underneath of the drawer, then clean inside the machine where the drawer fits into. Sometimes a build up of detergent/softener can cause this.
I hope this helps
Jan 19, 2009 | Candy CNW136 Front Load Washer/Dryer
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
ye sthey sell those local maytag store ok slips in and round
Feb 03, 2008 | Candy CNW136 Front Load Washer/Dryer
How do i fit a new door seal???
disconnect from mains not that easy first time. undo clip holding seal to cabinet. peel off seal and push inside drum remove top.i remember seal is held to tub by a giant jubilee clip but varies with model. undo clip and remove seal complete. fitting is more difficult lubricate slot that fits flange of tub with washing-up fluid - essential start at top fit an inch or so of slot onto tub flange. work in both directions forcing slot onto flange with thumbs as you go round. refit giant jubilee clip. refit seal to cabinet and refit cabinet clamp. test for leaks on rinse as water level is higher. this job is a knack so persevere
Mar 28, 2007 | Candy CN126 Front Load Washer
Candy CNW136 Front Load Washer/Dryer Logo
260 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
