How to connect printer to computer - Computers & Internet
    Master:
  • 341 Answers
Which printer is it? What kind of cable does it have. Well, for all these you need to have its drivers installed first and plug the printer's power cable to power extension/socket and the serial/parallel cable to the cpu
Posted on Apr 11, 2011
My printer says offline and won't print
Is your printer turned on?
Connected to the computer?
Showing an error message on the printer?
Typically, your computer will set a printer offline when it can't talk to it, so we do the above testing first...
If your printer is indeed on, and it's connected to the computer, there are things to try:
change connection wire.
change which port it's connected to on the computer
test on another computer
Jun 09, 2015 | Office Equipment & Supplies
Yellow light blinking
Typically, printers will blink a yellow light to indicate a communication problem between the printer and the computer.
1. Shut your printer and computer completely down.
2. Check connections to printer
3. Follow connected printer cables to the related computer port.
4. Check connections to computer
5. Turn the computer on and let it boot up
6. Turn your printer on.
Jan 20, 2013 | Office Equipment & Supplies
How to make mp760 wifi
This printer has only an USB connection that connects to your computer and cannot connect to wireless network directly. You can attach this printer to a wireless printer server/router to enable wireless printing.
OR
SET UP A SHARED NETWORK PRINTER
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this printer. This means the computer with the printer attached to it MUST be booted up at all times when other computers want to access the printer. You need to install the printer driver on the computer and configure it as a Shared printer. The other computers on the network need to add this printer to their computer. Follow these steps to set-up a shared network printer :- 1. Connect the printer to the computer and install the printer driver. 2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change the Share name, then click OK 3. Right click on the printer - click Properties - click Print Test Page to confirm printer installation. Follow these steps to configure the computers on your network :- 1. Open Printers and Faxes - click Add a printer - Next - select a network printer, or a printer attached to another computer - Next. 2. Select Browser for a printer - Next 3. Click on and expand the Microsoft Windows Network down to the computer with the printer - Next 4. Select Yes for - Use this printer as the default printer - Next - Finish 5. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
Dec 02, 2012 | Office Equipment & Supplies
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
Printer Problems
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 15, 2012 | Lexmark X5650 AllInOne InkJet Printer
Printer not communicating with computer
  4. Reboot computer.
Mar 06, 2012 | Lexmark X1240 All-In-One InkJet Printer
How to conect printer and i have only one lan conection it is not ossible to use at time net or printer
connect the printer to your computer through parallel cable or usb cable. install the printer on that computer and share it with the network. to share it, right click on the printer and select share. add drivers for other operating systems as needed. To set that printer up on other computers on you lan that might be wireless, just search for the computer its connected to through the network and connect to the printer. The computer that the printer is connected to must stay on so other computers can print.
Jan 14, 2011 | Office Equipment & Supplies
Computer connection
Click Start
Click Control Panel
Click Printers
Verify that the printer is "connected" and "online".
Verify that the "data" cable between your computer and your printer is fully-connected.
Apr 02, 2010 | HP Photosmart C5280 Printer
Connecting to printer through network
What operating system are you using? If it is xp it is very easy. Right click on your printer on x computer and click sharing and share it with an easy name like HP Laser, then on y computer open run command by going to start and run and in there you will type in \\xcomputer name which you can get by right clicking on my computer on x computer and choose computer name. once this is typed in run on y computer press ok and you will get window with some shared folders and also a printer. Just double click on printer and it will ask you to install drivers and it will connect but your x computer has to be on to be able to print from y computer.Same principle with 2 vista computers. If one is vista and one is xp this might be little more involved. Hope this helps.
Jan 09, 2010 | HP LaserJet M1522nf Multifunction Printer...
Printer/USB Cable Sharing
I suggest to create a network connection, for the printer.
First, connect the printer directly to one of the computer and then by the network connect the printer to the second computer. The second computer will not be able to scan, but it will be able to print.
Apr 16, 2008 | HP PSC 1610 All-In-One InkJet Printer
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
