Question about Bosch Nexxt 500 Dryer
No heatis coming from the dryer. What do you suggest?
  • Bosch Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 11, 2011
Installing a Honeywell RTH111B. The lines coming in are not color-coded.
W- Heat
Y- Cooling
G- Fan
R- Power/24v
B- Common/Ground
Line looks like your power, but beware that usually when it is labeled "line", its a 120v thermostat. I don't believe that this model thermostat is 120v. Just something to check. Hope this helps and good luck.
Jan 16, 2012 | Honeywell Heating & Cooling
Where can I buy a new heatiing element?
Hi stpat3017...
Go to the following webpage and order the parts you need for your smoker.
Please take time to rate me thumbs up
http://www.appliancefactoryparts.com/gasgrillparts/brands/masterbuilt/20070106.html
Sep 23, 2011 | Masterbuilt 20070106 Electric Smoker
My inglis model 43 00SQ is not heating properly. after it was moved, it now requires 3 or 4 cycles to dry a load of clothes.
There's a possibility that one leg of the 220v to the heating elements shook loose. Even a good manufacture can miss a properly tighten wire. It happens more that you realize. The other possiblity is that the rough treatment during the move could have caused a break in one of the heatiing elements. If you have voltmeter or have access to one, pull off the back panel that gives you access to the wiring, make sure the dryer is unplugged, and disconnect one of the leads to the elements. Now set your volt meter to the ohms position, kinda looks like a horeshoe, put one lead of the voltmeter to the detached wire and the other one to the wire that is still connnected. If the element is good it should show how many ohms or resistance the element has. It will show an amount, for this purpose it's unimportant, that means the element is good. If the reading is "0" that means the element is broken and neads to be replaced. Repeat with the other element.
There is another possibility that could have happened. During the move, part of the element may have come loose and is touching element somewhere in the middle. If this has happened it can be put back and your full heat will return. If it stays like that it will eventually burn out early.
Apr 09, 2011 | Dryers
My hamilton microwave is not turning and not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=-=-
May 21, 2010 | Maytag MMC5000 Microwave Oven
Old whirlpool dryer, replaced heati element, hearda pop no power
Sounds like you have a direct short to ground. Could be a timer problem or a motor problem or a wiring problem.. Best to call a reputable service company such as Sears.
Feb 06, 2010 | Dryers
Gas dryer has no heaty replaced element thermostat has continuity what else could i check
the heating element (the ignaitor) if it don't get to high temp the gas valve will not open. it might look red but it need to be very hot to cick the gas valve if you do not hear that the gas valve kick in then thats your problem ..
hop it will help you now ..let me know
Dec 07, 2009 | Estate TGDX640JQ Gas Dryer
Dryer runs no heat
it is probably the element but cut the breaker off then back on then run the dryer again IF IT STILL DONT HEATis then the element or even a limit switch on the element let me know what you find
bill
Jan 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Candy cic 60 fiter light
faulty exhaust thermostat or heater and thermostat complete, check for continuity should be normally closed (complete circuit)
Jan 06, 2008 | Candy CDC266 Dryer
Can't get my phone to switch on
YOU MUST CHECK THE BATTERY CONNECTOR IT HAPPENS THAT IT DOES NOT MAKE PROPER ELECTRICAL CONTACT OR OPEN THE PHONE USING TORX HEAD SIX SCREWDRIVER HEAD U CAN ALSO CLEAN THE PHONE WITH A METHYLATED SPIRIT AND DRY IT USING HAIR DRYER AVOID HEATI LCD.
Dec 17, 2007 | Sony Ericsson W800i Cellular Phone
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
869 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
