Question about Canon PowerShot A430 Digital Camera
Canon PowerShot A495 - Brand new. Used it once and took 40 photos. It then told me to change the batteries which I did. From then on it keeps saying "change the batteries" I've used alkalines and also rechargeable NiMH, These are either new or fully recharged batteries and still I get the same message. I have also cleaned the terminals inside the camera and even those on the batteries themselves. No change. This is clearly not a battery problem. This is a camera problem and its seems I am not the only one to have it. Is there a simply solution to this?
  • Canon Master
  • 10,263 Answers
Get it fixed under warranty.
Posted on Oct 31, 2017
advance
  • 107 Answers
SOURCE: S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Posted on Mar 23, 2007
SOURCE: displays "low battery" always
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
Posted on Jun 12, 2008
SOURCE: CANON POWERSHOT A530 LOW BATTERY READING
We had the same problem and it was so very frustrating. We sent the Camera back for assesment and repair only to be told there was nothing wrong with it. The solution was so simple we felt like real dummies.
All you have to do is use Energizer Lithium Batteries, since we started using them we have not had a problem with Batteries going flat or that annoying Battery indicator flashing.
Regards
John
Posted on Oct 15, 2008
welcomejee
  • 10594 Answers
SOURCE: Camera keeps shutting off.
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Posted on Nov 18, 2008
leecom72
  • 4806 Answers
SOURCE: Canon Powershot SX100 Change battery light
does the camera still work ok?
Posted on Nov 27, 2008
Why won't my Powershot A495 take a photo?
iIt seems that the battery is low or not powerful enough to run the camera properly. when the camera notices there is not enough power it will automatically shut down. ensure the battery is fully charged up on the charger and then try it. the battery type is
Canon NB-3L and if the camera is a few years old or has been stored for a long time the battery may need to be replaced.
if all these have been done and still the problem persists i would recommend a dealer have a look at the camera.
to replace battery open slider plate on bottom of camera and flip tab to release the battery pack.
I hope this was useful.
May 28, 2014 | Canon PowerShot A495 Digital Camera
Canon Powershot A495 Wont power on using the ON/OFF button
The problem is short on playback button due to humidity (see differences between the buttons on foto no.1), wich can be removed mechanically using a pin and making two holes(inlet/outlet) at the side of the button where no wiring running(!) and with a hypo carefully shooting air beetween the foils. It is useful to lift up little bit the spring button from the bottom foil to remove the short. A hair dryer can be also helpful to dry out the space between the foils. Please check the fotos and link too.
The camera will not power on by battery insertion when short is over. To protect buttons against repeted defects I used an adhesive tape to close the openings on the top of the buttons.
Canon Powershot A495 Wont power on using the ON OFF button page 2 General...9475eddd-e98e-40e1-9ff5-48f2b88aa22a.jpgimg_3172a-qpgfxpscyuxnmpq5faoemdbh-2-2.jpgimg_3180a-qpgfxpscyuxnmpq5faoemdbh-2-3.jpg
Nov 08, 2011 | Canon PowerShot A495 Digital Camera
My canon powershot a495 has a problem. it always
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jul 04, 2011 | Canon PowerShot A495 Digital Camera
On my canon powershot A495 my camera says lens error restart camera but i havent mistreated it how can i fix this myself
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 12, 2011 | Canon PowerShot A495 Digital Camera
My canon powershot a495 has a problem. it always shows low battery and turns off. i have changed to new batteries three times but the same problem. i bought 3 months ago. help please thanks
my canon powershot a495 has a problem.
Apr 18, 2011 | Canon PowerShot A495 Digital Camera
My Canon Powershot A495 is not getting detected by PC, I have to download photos.. Also I wont have External Card reader... Please guide.... TIA.. Amol Mane
Having gone over a month without a response to my query, I assume my suggestion to get and use a card reader solved the problem.
Apr 17, 2011 | Canon PowerShot A495 Digital Camera
I have a canon power shot A495 digital camera. problem with camera is new or fully charged batteries discharges after taking 4 to 5 photos when taken with flash
all the canon cameras batteries do not last more than 2 years.
the best would be to purchase a new battery which you can find at any Target, OfficeMax of a sort department stores.
Oct 11, 2010 | Canon PowerShot A495 Digital Camera
Canon powershot A430 says batteries need changing constantly
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation. Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 15, 2009 | Canon PowerShot A430 Digital Camera
Won't Turn On
I had same problem. Took it to photo store who sent it to Canon. They returned the camera stating liquid damage, would cost more to repair than to buy new one. I figured what the heck and sprayed WD 40 in the battery compartment. It turned on but wouldn't zoom. Sprayed it again and more worked. After the 3rd spraying it works like new and has for 9 months.
Mar 26, 2008 | Canon PowerShot S5 IS Digital Camera
Canon PowerShot A430 Digital Camera Logo
842 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
