Question about Sony Audio Players & Recorders
I NEED TO RESET Sony STR D365 Receiver BACK TO FACTORY SETTINGS, CAN THIS BE DONE??
    Master:
  • 344 Answers
I believe what you want to do is as follows. Turn off the power supply. Hold the buttons 6, 7, 8. And turn on the power. The display should activate all options, then turn on and off a few times and finally display End. Then the memory should be reset back to Factory.
Posted on Apr 11, 2011
How do I do a factory reset on Sony STR-DA3300ES receiver when the published method in the manual doesn't work?
While holding down TUNING MODE, press POWER on the receiver. All preset stations will be erased when you change
the tuning scale.
See some test modes
MEMORY CLEARING MODE
All preset contents are cleared when this mode is activated. Use
this mode before returning the product to clients upon completion
of repair.
Procedure:
1. While pressing the [TONE MODE] and [DMPORT] buttons, press
the [POWER] button to turn on the main power.
2. The message "MEMORY CLEARING***" appears and the
memories are reset to the default values.
3. When done, the message "MEMORY CLEARED*"
If you are a geek then try the SUPER MENU MODE .
Understand how to enter and exit the menu,
then See if Super reset on page 25 helps
Sony STR DA3300ES Service Manual Page 25
Oct 07, 2016 | Sony STR-DA3300ES
How do I reset the system
Turn the receiver off. Once off, you hold down the Power On button down for 5 - 10 seconds. This will reset everything to the factory settings.
Sep 30, 2014 | Sony STR-DA3000ES Receiver
Remote work properly
Make sure the batterys are good if so open the remote and check the led that send the signal it may be unsoldered
Oct 26, 2013 | Sony STR-DE875 Receiver
I also have a Sony STR-D365. Volume control works intermittently as well as right channel. Works if I "wind" the volume control up and down a bit and then goes out again. I reset it and no change. Any
There is a wiper on the back of the volume control that varies the resistance through the switch to control the volume. When you move it back and forth you are scraping the oxides off the switch and making it work again. I suggest you either get some contact cleaner and spray the control from inside (where the wiper is) or just change out the switch.
Jan 10, 2013 | Audio Players & Recorders
How to reset to factory settings
According to the manual, to reset all the function buttons to their factory settings, press I/O (O=Power button icon), AV I/O, {both of these buttons are at the top of the remote control} and MASTER VOLUME - {located on bottom right of remote control} at the same time.
Feb 03, 2012 | Sony STR-DE475 Receiver
How to reset sony str-dg800 to factory settings
For the STR-DG800 you need to power off. Then hold power button 5 seconds. When "push entrer" appears on display push "memory/enter" button. System will turn off and reset.
Nov 17, 2010 | Sony STR-DG800 Receiver
I need to reset my Sony DA5000ES to factory settings!!? Please help!!!
1) Turn unit off.
2) While holding dowm the MUSIC button, press the ON/OFF button.
"SF Initialize" appears in the display and all sound feilds are reset to the initial sttings.
Oct 17, 2010 | Sony STR-DA5000ES Receiver
Sony receiver str-da2000
Here is the link for the user manual if you need it; http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDA2000ES®ion_id=1 Check page 54 for details of the error message - it should disappear if the speakers are connected properly and the unit is switched off and on. Check page 17 for speaker connection details, and ensure they are all correct. Check page 19 for details of the factory reset/memory clearing. Hopefully this will clear the error code and let you set the unit up. Hope this helps, please ask again if no luck :)
Jul 14, 2007 | Sony STR-DE825 Receiver
1,809 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
