Question about Maytag MAH6700AWW Neptune Front-Load Washer
My Neptune MAH6700aww started acting up yesterday. The machine shut off in the middle of a load. When I pushed the Cycle Selector Dial to restart the washer it did nothing. I continued to push random buttons and it still would not turn on. After doing this a few more times the washer came on and water started to go into the tub but the panel only stayed lit for about 8 seconds and it died again. I then pulled on the door (which was locked) and the washer started up again, only to die again after about 8 - 10 seconds. I finally did get it started up and finish the load of clothes but it died 2 more times in the process. Any ideas on what might be wrong with this would be appreciated! Thanks.
    President:
  • 2,468 Answers
First,can you run the units diagnostics from the tech sheet located inside the unit in an envelope(should be located near the top)of the unit if so this should pinpoint your problem,then remove any and all cables especially the smaller ribbon signal cables,as moisture is a big culprit of these problems in electronically controlled washing machines (one at a time) and then clean off and inspect for moisture,corrosion,etc.and wiggle their connections carefully as you re-install them,if these don;t help,then its your interface keypad in the front,main control board,or the motor control board in the bottom near the motor thats bad and needs replacing
Posted on Apr 11, 2011
Why slow spinning?
a slow spin sometimes indicates that a out of balance switch might be malfunctioning
Oct 17, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Tip
Maytag Neptune Front Load Washer Shutting Down in the Middle of the C ycle
One of the common troubles experienced with Maytag Neptune Front Load Washers is the shutting down of the washer in the middle of the cycle intermittently or permanently. Later models with display will show a code "Lr or "Locked Rotor" signifying that no tach signal is detected by the machine control from the motor control. Earlier models will not display a code, but simply shut down and will not start.
The typical troubleshooting of the cause of the problem is by checking and ensuring the continuity of the connection between the machine control and the motor control. When the connection is good and the problem is not resolved, the motor winding is checked for continuity and the motor control is checked for component physical damage; such as blown fuse or burned semiconductor components.
The disappointing and frustrating scenario is when the motor windings are found to be okay and the motor control is apparently the cause of the problem; but the problem is not resolved when it is replaced. Typical troubleshooting suggests the machine control be replaced too; but the washer still does not want to start.
What is not well known is that the neutral line for the motor control is routed to the water valve solenoid terminals, not to the machine control. This connection must also be checked for continuity when such problem is experienced. Poor crimping of the wires to any the water valve solenoid neutral terminals may cause momentary loss of neutral feed from the power cord and result to the shutting down of the washer in the middle of the cycle.
Disconnect each of the white wire harness connected to each water valve solenoid and verify that the wire is proper stripped and crimped to the metal terminal connector of the wire harness. Make sure the wires fit snug on the terminals of the valve solenoids.
on Mar 28, 2010 | Maytag MAH6700AWW Neptune Front-Load...
We replaced pump on our Maytag neptune MAh6700AWW but we still got a nd code and it din't go into spin cycle?
cdmcdm5, did you ever figure out the solution to this problem? I currently have same issue. Have checked for obstructions multiple times and also ended up replacing pump. Still have same ND (no drain) code issue.
Jul 10, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune,shuts down within 10 seconds after start button is pushed
If it has worked for a year and your able to choose different cycles with the same result. It seems to functions with one common element failing. If the control unit cant detect how full the machine is with water it will shut down. Sounds like a water problem steming from your pressure switch. Not sure which model you have but usually it will sit on the water pump or under the console with a clear hose if under the console. If so a quick test of attaching an ohm meter set on continuity then blowing lightly to see if under pressure the switch reacts by closing if it doesnt then the switch is bad.
Sep 16, 2008 | Washing Machines
Maytag neptune washer
Since I haven't heard back on this in over a week, I will assume it's been resolved with the clarification questions.
Jul 04, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune error code d5
make sure it is installed correctly - there are 4 yellow plugs at the back that need to be taken out.
May 30, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing machine it shuts down water filling cycle
First thing to check is the filter,
DISCONNECT power
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
Jan 29, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag MAH6700AWW Neptune Front-Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
