Question about Yard Machines Garden
Getting to much fuel - Yard Machines Garden
  • Yard Machines Master
  • 7,482 Answers
Sounds like debris/trash in your Carburetor.
Check your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 11, 2011
Taotao 50cc scooter will initially start then sounds like not getting gas, cuts out & dies tried fuel cleaner still having problems keeping it running?? Any ideas??
If it acts like it isn't getting any fuel then that may be because it isn't getting any fuel. Often the obvious is the reason and people try to over think it.
Now, why isn't it getting any fuel? Or why is some getting through but not enough to run?
Fuel filter blocked, bent or kinked fuel line, blockage in the tank outlet, faulty fuel pump or fuel tap, fuel cap not venting so a vacuum is caused holding the fuel back, carb issues. There are lots of things to check and eliminate as the problem. Try working through the above list and see if that solves it.
Jul 25, 2015 | Motorcycles
2003. Why is no gas getting to the fuel rail?
Could be a "fuel pump relay" or ford equivalent that converts ECU fuel output demand signal to power to the fuel pump. To test jump direct positive to fuel pump and see if you get pressure at the rail. If you get pressure, that may be part of the problem. If not enough pressure (but measure) you may have a fuel pressure regulator or ford equivalent issue.
Jun 08, 2015 | Ford Ranger Cars & Trucks
Fuel Open Question 2000 Camaro fuel pump/ fuel
is the gas tank vent recirculate hose clogged?
bad gas cap?
Aug 17, 2013 | 2000 Chevrolet Camaro
No fuel getting to fuel rail.
fuel pressure regulator is what is in between the pump and the rails. it sounds like your regulator is restricting fuel flow
Feb 23, 2010 | 2006 Mitsubishi Lancer Evolution
Getting an EE6 after relocating heater. Have fuel
EE 6 usually indicates a fuel problem. You said you just moved the heater. If the fuel pump is making a loud ticking sound it means it isn't getting any fuel. Try pressing the fuel reset located on the lower right side of the heater. There is a float in the fuel sump that can get latched up so that it will not let any fuel into the sump if the heater is moved or jarred or the sump gets too much fuel in it. You say you have fuel, do you mean in your barrel or is it coming out the fuel line behind your heater? It is possible you have an air bubble in your fuel line that you need to get out. Hope this helps.
Jan 23, 2010 | Rinnai Toyostove Direct Vent Heater:...
Getting a reduced engine power light
Sounds like possible electronic fuel pump failure. when fuel pump gets weaker as the fuel level gets lower . Some folks have a tendency to run their vehicle low on fuel which will eventually shorten the life of the fuel pump.
In some cases you can fill the car up with fuel and the problem will go away in the early stages of the fuel pump problem. The problem comes back as the fuel supply in the tank gets lower. This is one sign.
Nov 22, 2009 | 2001 GMC Yukon
Engine not getting gasoline
CHECK TO SEE IF YOU HERE THE FUEL PUMP START AFTER YOU TURN THE KEY ON. FUEL PUNP, FILTER, FULE PUMP RELAY.
Apr 29, 2009 | Pontiac LeMans Cars & Trucks
94 dodge grand caravan no fuel in fuel rail
Dear Ron, you have replaced fuel pump and fuel filter. You have checked the fuel pump relay. Still no fuel in rail. Try bypassing fuel relay with jumper from batt to fuel pump. If o/k then check computer for ground to relay. This system uses a relay that is operated by the computer that supplies a ground for the relay to operate. The wire color is green,16 gage. If the ground is not available then "no fuel" Check this with a test light. Key on and crank apply test light to ground wire and other end of light to ground. You should hear relay click and get fuel. If this checks out you will need to replace computer or get creative with rewiring the relay so it works without computer input. Good luck Moe
Apr 24, 2009 | 1994 Dodge Grand Caravan
Fuel wont flow
You likely have a bad lift pump in the tank. You are working on the fuel pump on the fuel rail right? This vehicle has two fuel pumps one low pressure and one high pressure.
Mar 28, 2009 | 1989 Ford Econoline
Garden Logo
43 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
