Question about Samsung Galaxy Tab Tablet PC
The sim card is stuck, jammed I to my galaxy tab; how do I get it out?
    Problem Solver:
  • 7 Answers
Cut up a plastic card like a coffee loyalty card or something that is the same thickness as the sim, and make it the same width as the sim
Before gluing the tip of this card, push it in the slot to engage the release mechanism inside.
Your trying to get the mechanism on the removal cycle where the sim will be closer to coming out.
once that is done put glue on the plastic card tip.
Wipe all excess glue from the flat surfaces. you don't need much glue at all. if you bought strong grade super glue it tends fuse to sim and plastic together. so less is actually more.
let it dry well past the curing time as its better to be safe than sorry, lets face it, the sims not going anywhere and l doubt you need to make an emergency phone call.
then if your plastic card is close to the thickness of the sim card as mine was, it will depress all the sim contacts and come
out with suprisingly little effort. it felt on mine like you should have been able to tap it out in the first place.
Posted on Jun 23, 2011
  • 1 more comment
  • Zahir Jan 05, 2013
    Worked like a charm. Thanks
  • gothikprincy
    gothikprincy Feb 14, 2013
    i applied hard glue to one sim card and mounted it on the stuck sim and waited for few seconds and then pulled it out :D Awesome idea
  • Michelle May 20, 2013
    the vodashop entered a micro sim into the full sim card hole and it got stuck, now this card is far smaller do u think that trick will work with it too? vodashop is useless and has no idea
2 Suggested Answers
  • 1623 Answers
SOURCE: I bought the Samsung Galaxy Tab from a Telstra
the galaxy tab will be locked to the provider you got it from, which is why your sim isnt being recognised. You will need to unlock the tab to allow it to accept any sim. To get it unlocked you need to request an unlock code from Telstra
Posted on Apr 12, 2011
Sim card for Samsung Galaxy tablet 4?
A SIM card is for 4G LTE internet service, so if you have a Samsung Tab 4 ensure it is 4G capable before trying to insert a SIM card. If you try to insert a SIM card into a SD Card slot you may damage the card reader.
That being said, I believe it is located on the right side of the tablet. Sometimes the SD Card slot and the Sim card slot are right next to each other. Once you open the cover that reveals the slots there should be small icons for the SD Card and the Sim card. Normally, the SIM card slot will have a little notch on the icon. Attached are guides with pictures.
http://www.samsung.com/us/support/answer/ANS00030415
SIM card Samsung Galaxy Tab 4
Oct 22, 2016 | Samsung Tablets & eReaders
Is a samsung galaxy tab 4 7.0 compatible with straighttalk ?
It depends on which model of the Galaxy Tab 4 you have. The unlocked Galaxy Tab 4 3G is compatible with the Straight Talk GSM network and has a SIM card slot. There is a Wi-fi only model which will only talk to a cellular network through a hot-spot device.
I hope this helps.
Jan 07, 2016 | Samsung 7 Galaxy Tab 4 8GB White
I need a download manual.
PDF]User Manual Manua - Verizon Wireless
cache.vzw.com/multimedia/mim/...galaxy_tab2/galaxytab2_manual.pdf
relating to the SAMSUNG Galaxy Tab, including but not limited to, ... network solutions selected by the software provider, solution provider or user. ..... 2. Push the 4G LTE SIM Card in gently to release the lock. 3. Carefully slide the 4G LTE SIM ...
Support - Wi-Fi Tabs GT-P3113 ' Samsung Galaxy Tab
www.samsung.com > ... > Galaxy Tab > Wi-Fi Tabs
Samsung ElectronicsVisit Samsung today for Samsung Galaxy Tab® 2 7.0 (Wi-Fi), 8GB. You'll find ... Manuals. User Manual ver.1.0 (EN, 4.95 MB). Jan 29, 2015. Download (pdf)
Support - Wi-Fi Tabs GT-P5113 ' Samsung Galaxy Tab
Oct 31, 2015 | Samsung Galaxy Tab 2
How do i find puk code to unlock sim card to a samsung galaxy 3 tablet
As I understand from personal experience, the PUK code is only available from the service provider. You need PUK code after you entered the wrong PIN 3 times for the SIM card. Call your service provider or get a new SIM card.
Jan 10, 2015 | Samsung P1000 Galaxy Tab Unlocked Android...
I do not know how to transfer contacts from sim card to galaxy tab S
To copy contacts from sim to phone on Samsung Galaxy S Tab:
  1. On HOME SCREEN, tap Applications
  2. Tap Contacts
  3. Press menu.jpg and choose Import/Export
  4. Select Import from SIM card
  5. Press menu.jpg and tap Copy to phone
  6. Tap Select all
  7. You're DONE!
Jul 01, 2011 | Samsung Galaxy Tab Tablet PC
I bought the Samsung Galaxy Tab from a Telstra network provider without a sim card. I am with Vodafone for my iPhone and have 3G on the sim. I want to put the sim card into the Tab for internet...
Apr 12, 2011 | Samsung Galaxy Tab Tablet PC
Can i insert sim in samsung galaxy tab. 10.1 ?
There should be a little door on the bottom right of the device that you can insert the sim card.
Open the door, insert the sim with the gold contacts down and close the door.
Here's a video as well!
Mar 14, 2011 | Samsung Galaxy Tab Tablet PC
Can i insert a sim in samsung galaxy tab 10.1 ?
Welcome to Fixya. Yes you can see image below.
Thanks for using Fixya
My browser returns "web page
check the wap settings...
if you are not able to figure it out then contact the mobile operator for wap settings
Samsung Galaxy Tab Tablet PC Logo
3,186 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
