Question about Acer AL1916W 19" LCD Monitor
Input Not Supported
O jave an Acer Monitor and :Input Not Supported" keeps rotating on my screen. I put it in safe mode but it does not remove it. And I cannot get
quadplex to come up. What can I do?
  • MCantrall Aug 07, 2008
    I dont know what U are talking about.
    How do I bring up "Display Setting"?
    Scholar:
  • 191 Answers
I don't think you can really do an HDMI to VGA or HDMI to DVI to VGA. If the monitor doesn't support DHCP, it probably won't work with the HDMI output
Please specify which cable are you using for video signal.
Posted on Aug 19, 2008
  • Moses Clive
    Moses Clive Aug 19, 2008
    In case you are getting video on safe mode than try to remove the driver in safemode and when you will go back to the normal mode try to install the latest video driver and set your display to lower the resolution down to
    1152x864 or 1024x768 and tell me the status.
    Genius:
  • 1,689 Answers
Right click on the desktop screen then go to properties, or you may go to control panel and you will be able to see the display settings there
Posted on Aug 07, 2008
  • 3,037 Answers
The problem is that your hertz rate is set to 75 and your acer monitor doesn't support that. Go into the display settings and change the hertz rate to 60.
This solution is provided from Shane89, another fellow expert of the Fixya community
Let me know if you have any further questions with this
my best to you
    Genius:
  • 1,056 Answers
I've seen this error when replacing a CRT monitor with a Flat screen.
If you have a CRT monitor around, plug it back in, and change your video settings.
Lower the resolution numbers (800x600 should be fine) and lower, or match your refresh rate. (it should have the ratings on the back of the monitor)
Find what your Acer is rated for (probably 60 to 72 Hz).
You may have to swap them back and forth a few times to get it right, but once you do get it to display, you can get it to "talk" to each other, and fine tune the display rates.
Let us know how this works.
    Champion:
  • 221 Answers
You may want to check the output settings of your computer:
This can be done by right clicking on the desktop, going to 'properties' in xp, or 'personalize' if you are on vista
Then go to the settings tab, and set your setting to 1024 X 768
See if the message is removed. Also check your cabling! Make sure all plugs are inserted properly!
  • Suvvy Roy Aug 07, 2008
    to change the hertz setting, under the settings tab, click 'advanced' and then 'monitor'
    there change the hertz setting to 60HZ
    and yes it does seem like a hertz setting problem, so no need to change resolution! just follow the instructions and change the Hertz setting to 60 HZ
    Genius:
  • 2,035 Answers
The problem is that your hertz rate is set to 75 and your acer monitor doesn't support that. Go into the dispaly settings and change the hertz rate to 60. Fixed my a couple of minutes ago.
  • 6,487 Answers
Just go to into the dispaly settings and change the hertz rate to 60 that should fix that ...
Hope that helps.......
  • Mark Gil
    Mark Gil Aug 07, 2008
    If you can just Right click on your desktop then click on, Properties >Go to settings and click on advance then a new window will open adn go to monitor tab set the Screen refresh rate to 60hertz...
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
When i put pc on this message comes up on screen saying input not supported and it floats round in a little box.
This generally means you have the display resolution set higher then the monitor can support. To fix this press F8 after you turn the computer on. You may have to press it a couple times before the windows loading screen. A black menu will come up. Select safe mode. Your PC will load into safe mode with minimal drivers and settings. Go to the control panel and select display. Change your screen resolution to something lower then the setting is is at right now. If your screen is 19" or smaller try a setting of 1024x768 for starters. If its 20" or higher try 1280x1024 for starters.
Regards, Chris
Jun 30, 2011 | Acer Computers & Internet
My laptop got broke, i'm using a small flatscreen monitor plugged into the back. a screen says "ATTENTION INPUT NOT SUPPORTED" just keeps floating around the screen. i don't know how to fix it
Start in safe mode and change the resolution to 1024x768 and 60Hz refresh rate. Restart and reset the resolution at the native of your display and 60Hz refresh.
Oct 28, 2009 | Acer AL1916W 19" LCD Monitor
Input not supported on my screen I have a Acer P191W monitor
your resulition is set too high. to fix this you need to either change it on another screen if you have one or restart your computer into safe mode. usually in safe mode it will be on the lowest setting and you will have full access to change it from there.
Jun 30, 2009 | Acer P191WBD LCD Monitor
How to change resulution when you get input not
Try starting Windows in Safe Mode. During boot, before windows starts loading, just keep tapping F8, until a menu appears in which you can select Safe Mode. In Safe Mode, set the resolution to a safe, low value in the control panel. Then reboot normally, and everything should work fine.
Jun 07, 2009 | Acer AL1916W 19" LCD Monitor
Input Not Supported
You need to go into display settings, click advanced, and then click the monitor tab, and change the hertz setting to 60 HZ
Aug 07, 2008 | Acer AL1916W 19" LCD Monitor
Input not supported
Vista Driver perhaps required
Try Acer Website
Jun 13, 2008 | Acer AL1916W 19" LCD Monitor
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
174 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
