Question about Toshiba Satellite A45-S120 Notebook
Am getting a system cooling message, it says that the cooling system of the machine is not working, how do i know whether the system fan is operational, what could be the cause of this
  • 1,179 Answers
You should be able to hear and feel the fan spinning. The air should also come out of the laptop usually on the left or right side near the hinges of the laptop.
It is also possible that the cooling system has not failed completely, in other words it is operational but not running efficiently.
Be sure to raise the laptop off the table to allow air to be sucked in from the bottom of the laptop.
It may need a service and a clean.
damnor01
Posted on Apr 11, 2011
My chevrolet uplander radiator cooling motor fan only working, when the A/C is turn on. Any relay or fuse that I need to check?
It would be useful if you had mentioned whether it was a radiator cooling fan motor or a heater/ventilation fan.
It is usual for the cooling fan to switch on with the A/C is on unless the ambient temperature is quite low, otherwise it only operates subject to engine coolant temperature via a thermal switch fitted into the cooling system and/or the engine management system.
The heater fan is either directly switched and faults relatively simple to trace or subject to the whims of the climate control if fitted when a degree in magic is needed along with a box of tricks.
Aug 22, 2015 | 2006 Chevrolet Uplander
System cooling message
check whether the fans are properly working or not or use a cooling pad
Jan 31, 2013 | Toshiba TECRA M9 Notebook
Fixed every possible cause but still overheating
checked water pump for circulating the coolant?
checked the radiator if the coolant circulated correctly?
thermostat renewed?
thermo switch checked whether is working?
fan switch checked whether is working?
checked whether the matrix could circulate the coolant?
ckecked whether there is any valve on the matrix hoses and is working?
have you bled the cooling system ?
have you checked whether you have a cylinder head gasket with problem and pressurized the water?
checked whether have a cracked cylinder head and on accelaration expanded the water hoses?
have you checked whether the radiator cap is working ok?
have you checked whether the radiator cap is with the correct pressure for the cooling system?
checked whether the cooling fan is working?
Sep 05, 2012 | 2001 Mazda Protege
PC get shutdown automatically
It can happen in several cases. Like:1. If your processors cooling fan does not run properly or stops running , your processor gets over heated and will automatically shutdown to prevent damage of your motherboard. In this case check this first, If is runs but not seem so smooth, just clean it- dust can jam the cooling fan.
2.If your heat sink under the cooling fan is not perfectly fit on the processor, cooling fan will not able to cool it and will result your machine shutdown!
3. In case of Bad power supply, it can also happen. Check your power supply.
4.If your machine have defected RAM or became defected, it may happen. In this case you may have blue screen with message before shutdown your machine.
5. If you have operating system of Microsoft Windows, please check your hard drive for virus. Virus can shutdown machine with a common period of time! Damaged OS which occurs often in windows operating system also can force to shutdown machine.
Please check which one is in your case. Please mention problem details like something unfamiliar for further query.
Jun 25, 2012 | AcerPower PC Desktop
Hallo, I have a Lenovo ThinkPad SL510 2847 and I get unexpected shutdown in a different intervals. It may be for example 10 minutes or 3 hours after the Windows starts. The system is ready to start...
It could be that the machine is overheating, if it's shutting down. Try ensuring that the vents are clear of obstruction, and that they are clean. If you can get to the cooling fan, then ensure that this is also clear. Don't use the laptop on your lap, as this tends to block the cooling vents as well.
It may also be worth checking to see if you get any error messages before it shuts down - in case it's something different (although I know that Windows 7 doesn't have an SP2 yet - so are you using Vista, or 7, SP1?)
Jul 23, 2011 | IBM Lenovo ThinkPad SL510 Notebook
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
When i boot up the laptop i get a message 'Main Fan Error' the fan runs on start up then stops just before i get the error message. Fan will not restart... Joseph
This message means that the fan on your CPU (processor) is failing or has failed. This is not good because if the fan on the CPU fails your CPU will overheat and cause your machine to lock up and become non-functional till it cools down and then the same cycle will repeat till the fan is replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 11, 2010 | Gateway (8008625) Cooling Fan, Heatsink...
Toshiba A45 S151 Cooling system probelm.
Just to be sure, check the temperature of the system with any 3rd party softwares and see whether its in the optimal range.
Jun 03, 2017 | Toshiba Satellite A45-S151 Notebook
My IBM T22 LAPTOP cooling fan does not work . When I start LAPTOP SYSTEM START BUT FAN NOT RUN. I dont know whether it its problem or not.
If the fan is not running, your computer will definately have a problem very soon. Sometimes, the fan is just clogged up by dust and debris. Head down to a local computer store or one of the box stores and purchase some compressed air dusters.
Dust out the fan and vents as best you can. If the fan still does not spin, your computer will easily overheat and, in all probablilty, shut down on you at random.
If left for too long, this could cause multiple other problems for your computer. I would recommend you look at getting the fan replaced as soon as possible if you cannot get it to work by dusting it out.
Good Luck!
Aug 07, 2009 | Computers & Internet
Toshiba 4010 is giving me a "warning, problem with the cooling system message" Machine gets real slow. How can I inhibit this message, I have it on a cooling pad?
The electrical components in a PC generate heat, and fans inside the PC help move the air to keep the components from getting too hot. Excess heat will cause the fans to run constantly, damage components, and limit the speed of the CPU. All of these problems with high power and high heat will cause applications to work slower than normal. One of the main functions of the BIOS is to monitor the temperature and adjust the operating conditions. While the sound of the fan running all the time can be annoying, it may the first clue that your PC is running as efficiently as possible. To help your PC as cool and as efficiently as possible, do one or more of the following corrective actions.
  1. Update the BIOS
  2. Keep air vents clear and clean
  3. Minimize disk operation
  4. Minimize CPU operations
  5. Check whether FAN is enabled in BIOS
Thanks Rajesh
Jul 13, 2008 | Toshiba Computers & Internet
Toshiba Satellite A45-S120 Notebook Logo
120 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
