Question about Brother MFC-8480DN All-In-One Laser Printer
My printer showing paper jam n i cant find any paper stuck in the printer checked in n out?
    President:
  • 287 Answers
Hello! Welcome to FixYa
Paper jam
means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Brother Printers service provider.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!
Concerned: Angel Bird
Posted on Apr 11, 2011
Corysf62
  • 188 Answers
SOURCE: paper jam
Here is the most important thing to understand about paper jams in any printer....
The printer does not know if there is a paper jam anywhere in the printer.
What it does do, is respond to sensors ( optical sensors, either open or closed, by plastic flags). These flags are moved as paper moves through the paper path.
One example of a paper jam message when there is really no paper jam, is when the feed rollers are worn and do not pick up paper from the paper tray.
When you start printing, the printer expects that first sensor to open ( paper passes the sensor ) at a very specific point in time. If the paper did not get picked up from the tray, then the printer will ASSUME that the paper must be jammed somewhere because it did not reach it on time.
Now this will also happen if in fact the paper did get picked up and then jams prior to the sensor.
So... if you get the picture of how this works, understand then too, that if the printer is showing a paper jam message at power on, then one of the flags is open when it should be closed.
If you do not actually have a piece of paper holding this flag in the open position, then the flag is possible broken.
I usually see this kind of damage occur after a true paper jam, where the paper is removed either in the wrong direction ( pulled out back the way it was going instead of the way it should normally travel ), and this breaks the flag, or it was pulled out forcefully again, catching on and damaging the flag.
All of the above pertains to ANY printer, and not just yours. you must take care to fully inspect every inch of the paper path, from the paper tray, to the exit, use a flashlight, and look for the sensors and make sure they are not blocked or broken.
Good luck,
Cory
Posted on Nov 06, 2008
Soulvisitor
  • 1113 Answers
SOURCE: paper jam 202 with no paper in printer
This jam is refering to back door, jam in fuser (hot bit) Double check no paper is wraped around fuser rollers.
These machines have a fuser at rear if you look at he fuser from the back, on it you will see, two thick fuser rollers (ones rubber), paper runs threw these then it hits a little black switch (your machine thinks this switch is activated) and then a series(3,4) of small rubber exit rollers, this switch (between middle and left) can get damaged it also likely that a piece of paper is concertinaed in fuser.
Also remove print cartridge and look behind it, if this machine has duplex unit installed you will need to lift it off that first to axcess all areas.
Check all doors are shut.
Posted on Nov 13, 2007
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
  • 9 Answers
SOURCE: paper jam
There is an end of form sensor in the paper path that is likely stuck or the rollers cannot turn due to some other Jam. The machine will throw that message if those two mechanisms cannot function. Look for debris in the printer - give it a good shake.
Posted on Oct 10, 2008
  • 159 Answers
SOURCE: HP 2015 printer has a constant paper jam light
Your printer has a long history of problems with its formatters. Apparently you may be able to download updates, but they don't always work. You may have to replace it. More information here:
http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1228501642160+28353475&threadId=1210144
Posted on Dec 05, 2008
My lexmark inkjet printer model p4350 requests to clear paper jam. How can i clear it when i still cant identify a paper stuck inside the printer
Hi
If you cannot see any paper inside the most likely cause is the microswitch that detects a jam has stuck in the on postion or there is a small bit of paper stuck on it look for the switch and un jam or remove the small bit of paper on it
Cliff Cook
Aug 03, 2014 | Office Equipment & Supplies
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
My HP photosmart PSC2410 XI printer is showing "clear carriage jam"what should I do?
Points to there being paper stuck in the feed rollers, if you have cleared the jam, there may be a shred of paper still stuck, try to examine and remove.
If it IS fully clear and the indicatiors still show a paper jam, check the feed rollers are making contact with the paper, that the paper detector has not been bent upwards ( fooling the printer into thinking that there is still a jam).
Try rebooting the printer, if the problem still shows, this is a job for a qualfied technician
Mar 31, 2011 | HEWLETT-PACKARD PSC 1610 xi All-In-One...
Machine says paper jam but cant find any paper stuck?
While working with your Samsung printer you may encounter a paper jam. Paper jams are usually obvious, but sometimes you may face a situation when there is no indication that the paper has jammed up the printer, in that case, open it up and visually inspect it to search for the jammed paper.
Nov 29, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam showing when no paper in the printer
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 06, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Have a samsung ml2150 which keeps saying paper jam 2 i can see no paper stuck anywhere any ideas please paulmcfc
Inside the printer,there is a sensor which detects the paper.if something is still stuck in between the sensor or some dust is set between the sensor can make the printer feel that paper is still stuck-ed up.
In that case it will keep on showing the paper jam.to solve this issue,you need to open up the printer and clean the sensor assembly gently.once its done it will no more show paper jammed error.
thanks.
Aug 31, 2009 | Office Equipment & Supplies
Printer is saying theres a paper jam but i cant see anything was working fine then it made a funny noise and stopped
Hello sir; Paper jam ,it doesn't real mean paper jamming inside, it could be something else, such as paper clip, or staples etc. check very carefully you will find out something stuck over there.
Aug 18, 2009 | Office Equipment & Supplies
Won't print, and shows Error Code 3
Check to see if anything is stuck inside. Sometimes a small fragment of paper gets stuck inside and triggers the "jam" message.
Feb 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
PRINTER SAYS PAPER JAM 23 ..
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
thanks J
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Brother MFC-8480DN All-In-One Laser Printer Logo
601 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
