We have a 400 year old house, and have a problem with a large amount of water pooling in the kitchen. We are having trouble establishing where it is coming from, with no obvious leaks found as yet. The water looks clean, and we are wondering if there is anyway of testing it to establish if it is mains water or spring/ground water - we have heard that there used to be a well in the back garden! Can you advise on the best course of action to establish the source of this water? many thanks
    Genius:
  • 1,400 Answers
Hello
First verify you have nothing leaking in your kitchen.Sink, refrige,drains.Heating system is it hot water? make sure its not leaking also.
Im guessing this home is on a slab or has no basement?One way to find out if the water table is high is too go outside and dig down about 2 feet on all 4 sides of the house.Wait about 4 to 6 hours and see if the holes fill with water.If any of them do then you have a high water table or the old well is filling up.
Your water main if its city water should come in off the street,find the shut off near the curb and follow it too the house.
As far as testing the water,your local health department or water dept should be able to test it for you.
Or there are some places to get your own.http://www.filtersfast.com/water-test-kit-cat.asp
If the water table is that high your going to need to have a contractor pump the ground out by putting long pipes in the ground and hoses and actually pumping out the water.Or have the well sealed and filled.
Posted on Apr 11, 2011
Testimonial: "Thanks for your help. Much appreciated the quick response. "
Our pool is about 90000 litres of water so how big filter do we need please
If you have a above ground pool go with the Cartridge or sand, and if underground go sand or D.E. All have their ups and down you should find out what you want from them specifically cause they all do varying amounts of the same thing.
Sand Filters
(Filters using literally sand)
For sand filters, on inground pools, I like to use a 30 inch tank diameter, which is a 4.9 sq. ft. filter surface area, and holds 600 lbs of sand. For small pools (under 20,000 gals), I might advise the next size down (24 inch tank), if the budget is tight. But never go smaller than a this for an inground pool.
Cartridge Filters (like a air filter)
I have a rule of thumb for cartridge pool filters. 100 sq. ft. of filter surface area per 10,000 gals of pool water, as a minimum. I like to see the 400 sq. ft. models on inground pools above 25,000 gals. These can go an entire season without cleaning in most cases.
D.E. Filters (Ground up fossilized algae)
Because they offer the most superior type of filtration, people tend to go small with DE, and buy a 24 or 36 sq. ft. DE filter. Ugh - go Big! Nothing below a 48 sq. ft. filter, and if your pool is over 25,000 gals, go with the Big Boy - the 60 sq. ft. filter.
Swimming Pool Blog
Also make sure the filter can take the amount of water that the pump is pushing through it.
Jul 23, 2015 | Pool & Spa
Will adding acid to pool water kill my salt level
Hi, this is John the Hayward tech. The only way salt leaves the pool is from splash out, filter back washing and any other means by which the water is deluted causing the salt reading to reduce. In some areas large amounts of rain will cause the level to lower. Adding pool acid will not affect the salt level.
Aug 31, 2014 | Pool & Spa
Does the salt system affect my pool pump?
Over time it will attack the motor, yes. There are pumps especially designed for salt water pools, with 316 stainless steel parts, and an open section in the casing between impeller housing and motor casing, and seals on either side with a flinger on the shaft. Eventually though the salt will get to the motor somehow. Mind you we are talking years. On my salt water pool, now 23 yrs old, it is on its 3rd motor, which is about 5 yrs old.
May 19, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
Water Isnt Getting Hot
Could be that the plumbing got clogged while the system was idle
May 13, 2013 | Sta Rite Pool & Spa
The pool timer goes on, the hayward 2 HP pool pump turns on and then causes the circut breaker to pop. After two, three resets, it starts to work. This problem started a week agao. The pump is 9 years old.
could have a bad run capacitor or a start capacitor . search your area for your local pool pump motor repair guy with free testing, 9 years old that motor needs to be rebuilt.. i charge 85.00 to rebuild a 2hpincludes a free shaft seal.. remember to prime the pump with water after a repair !! best of luck .. oh breakers become week after amount of time time .. and ask the repair guy if this is the right size pump for you pool.. 9 out of 10 times its way too big !.. jay longwood florida
Sep 08, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
Immediately rises and stays on top of the water
You might need to check to pool cleaners floats. You might have too many floats attached or might have them improperly placed. It is also possible that you have the pressure thought the cleaner turned up to high. It could be propelling the cleaner off the pools floor. More severely, it could be that your cleaner head is cracked and has taken on large amounts of water. You would need to have this professionally prepared.
May 20, 2011 | Hayward Phantom Pool Cleaner Complete with...
Whirl Pool Duet Sport WFW8300SW00 leaks water from the detergent drawer after about 30 seconds of water running...please help!!
the water pressure is to high turn the tap down and wind the front feet right up. very common the water comes in to fast and splashes over the tray & down the front panel that will rust. replaced over 100 front panels still under warranty due to this problem.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Leak in the water dispenser
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jun 30, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Unable to get water clear last season could it be faulty pump
Although the chips inside the pump could decrease the efficiency i doubt that this is why you were unable to get the pool clear. What type of filter do you have, how old is the media inside it, and was the water just cloudy, or did you have algae problems?
Apr 06, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
