Question about Ricoh Office Equipment & Supplies
RICOH SP 3400SF SERVICE CODE SC542, plz help me clear the code.
How do i reset SC542 error in Ricoh Aficio SP300DN?
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Feb 23, 2015 | Ricoh Office Equipment & Supplies
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 28, 2014 | Office Equipment & Supplies
Error sc542 service
SC 542 Fusing temperature warm up error.Fusing lamp defective,poor fusing unit connector,thermistor warped or broken,thermostat has tripped,power supply defective.After verify the componenets try reset the error.Enter in service mode:Press the yellow key and press 107 and keep pressed the stop key 3 second.Touch the SP window on screen open the front door and turn OFF the copier.Wait 1 minutes ,close the front door and turn ON the copier.If the error code persist change the upper fuser roller and the thermistors.
Jan 01, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
by one immediately.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Error sc542
"clear modes", 1, 0 , 7, then (hold) "clear/stop" for a few seconds until "sp mode" comes up. turn main power off/on (red switch).
If code comes back there is trouble with the fuser that needs to be repaired to clear code permanently.
Apr 21, 2009 | Office Equipment & Supplies
350 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
