Question about Candy Washing Machines
I have a Candy Washer Dryer 1400 aaa model GO W 464 D and I keep getting E11 coming up on display about 2 minutes into the cycle - please help!
  • 1294 Answers
SOURCE: Washer/dryer stops mid cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 30, 2008
mumma_1
  • 903 Answers
SOURCE: candy washer dryer 1400 spin cmd 146
try taking the soap dispenser draw out a give it a thorough clean inside and on the underneath of the drawer, then clean inside the machine where the drawer fits into. Sometimes a build up of detergent/softener can cause this.
I hope this helps
Posted on Jan 19, 2009
  • 141 Answers
SOURCE: FAFW3577KWO washer-code E11
Your machine may have short circuit with the inlet valve since you are facing problem after 5 to 6 mins you are suppose to change the inlet valve
Posted on Dec 24, 2009
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
  • 298 Answers
SOURCE: lost instructions for my washer/dryer. e11 keeps
u can get a sevice manual on this at appliancerepairplanet.vstore.ca
Posted on Dec 01, 2010
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
Candy A*AAA 1400 spin 7kg Machine turns on, water doesn't come into machine start of cycle except sounds as though it is going to. Emptied the filter at the bottom of machine lots of water nothing...
The valve through which water comes in2 the washer is opened electrically and it is the what-type-of-water-u want-2-use selector switch that controls the opening & closing. E.g if u select cold water it opens valve for cold water and closes valve for hot water. There is a place (most likely at the valves where pipes meet washer) where electrical connection e.g due 2rust, has been lost. Thus the valves r not being opened by the selector.
Mar 01, 2013 | Washing Machines
I have a Hoover vhd sensor Dry Washer Dryer and its come up with error E11. Can you help ?
Hi I had the same problem about once a week and every time it happened I had to turn off the washer off and leave for a while and start new wash cycle. It worked for a while but eventually it started to throw E11 once I put it on (not the middle of cycle it used to do). I had to result to call the repair man. He checked all the hardware and nothing was wrong and re-install the program on the board and it stopped throwing errors. After 4 month of problem free period, it gave me E11 again today though..
Jun 23, 2010 | Washing Machines
FAFW3577KWO washer-code E11 washer will begin wash cycle and stop after 5 or 6 minutes. display reads PAU- when start and cancel buttons are simultaneously pushed I get an E11 code. What is E11?
Dec 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Candy washer dryer 1400 spin cmd 146
I hope this helps
Jan 19, 2009 | Candy CNW136 Front Load Washer/Dryer
Candy CMD146 Washer/Dryer
This machine has selfcondensing system. The condense water is beeing pumped out with the cooling water. The watertap MUST be open during drying. It also may be caused of overloading. The most W/D combos is just able to dry just the half of a full load in one time.
Jan 10, 2008 | Candy CN146 Front Load Washer
Washing Machines Logo
547 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
