Computer can not see externat hard disk - Computers & Internet
    Master:
  • 341 Answers
Change the cable. or try using a different external hard disk
Posted on Apr 11, 2011
How do i install cam on my laptop?
hi,
DV cams, doesn't install, it is normally directly recognised as firewire cam (if what you want is to capture the recordings or live), you have to set in your capture program the right device...
now, if what you want is to use the hard disk function (memory stick) you have to light up the camera and then plug it in usb port, windows will recognize it as thumb drive (externat card reader )
May 14, 2014 | Sony Handycam DCR-HC90 Mini DV Digital...
Tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 | Computers & Internet
When I start the computer, the XP logo appears and then disappears, then reappears trying to start.. The computer will not completely start. It just cycles through this trying to start mode
The Netbook in infected by a boot virus.
to resolve take the following steps:
1- boot from anothe device:
a) memory card
b) USB key
c) or externat CD or DVD drive
2- Scan the hard drive with an up to date Virus scanner (like DrWeb or Bitdefender)
3- Reboot your PC and enjoy.
P.S.- Don't forget to rate this answer...
Jun 13, 2011 | HP Mini 1000 Netbook
I plugged in the wrong power cord to my p/n 9nk2ag-500. Is there a way to fix? or self extract files? I keep hearing about a SATA gadget that can convert any externat HD to a USB powered, will this bypass...
yes if the hard drive is not damage
you can use a external sata case to read your hard drive.
remove the casing off the seagate freeagent to get to the hard drive.
you need to get a 3.5" external sata case.
you can get one from newegg.com or at your local fry's
this is what i have
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153066&cm_re=thermaltake_sata-_-17-153-066-_-Product
which supports both 3.5" and 2.5" sata hard drives.
Mar 20, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Your transcend storejet2.5 is not getting detected
the problem might be that your external hard drives circuit might have burnt,
just open the casing remove the internal hard drive and try connecting to a pc esata connector, if it is being detected you have a good hard drive and data mit have not been lost, just buy a externat casing, esata or ide and put back you hdd.
Dec 22, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Not detecting hard disk
first thing to do is to remove and reconnect the hard disk to the system. devices like hard disk not detected often is just a result of loose connections. if this will not work, may be a good idea to test another hard disk with your computer or test the hard disk on another computer to isolate if the hard disk will need to be replaced.
Sep 04, 2010 | Computers & Internet
My computer memmory full?
because d drive is the cd drive. looks like you are going to go and buy an externat usb hard drive and transfer some of what is on the c drive to the external 1 it will be called e drive..have fun ..
Nov 15, 2009 | Acer Aspire 3680 Laptop
Dell latitude D610
This fault usually means the hard disk has failed or the disk controller, in most cases it is the hard disk that has failed.
Check the BIOS settings and see if the hard disk is detected, if not it is probably a faulty hard disk.
When you boot up the computer does the hard disk LED light flash and can you hear the hard disk spin up. If the hard disk is making a clicking noise then it is definitely faulty.
To test the hard disk another way, remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer cannot detect this as an external hard drive and you can't open the folders and files, this confirms it as faulty.
To get the computer operational again, you need a new hard drive, Install Windows on the new hard drive with the computer's device drivers and your programs.
Sep 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Display problem?
It appears the video info is not getting to the LCD screen, possible faulty video cable and or loose connector.
Reseat the cable/connector that connects to the motherboard.
Jul 20, 2009 | Samsung SpinPoint M40 MP0302H...
Computer/modem
ok tilly
how would you like the ethernet port installed on your pc? should i say that the modem is internally installed and that you have an externat port for the ethernet...
Apr 26, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
