Question about HP Photosmart R707 Digital Camera
R707 wont power up
I recharged the battery, plugged it in correctly, then i held the little slider to the right and it wont turn on. What could be causing this?
  • gemarcus Aug 07, 2008
    also, when the battery is first inserted, the video light next to the eye piece lights up for about 3 seconds.
    Problem Solver:
  • 13 Answers
When you put your battery in,, also put the power on the camera so your adaper on the net, and the end of it in the little hole next to the usb port,,, then try to turn your camera on,, this could help,, i had a similar problem and accidentally i tried to recharge it while the battery was still in the camera and it helped,, i hope i helped ya,,
Posted on Sep 30, 2008
Turns on for 2-3 seconds shuts right off battery is ok hp 707 pho
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera, and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. "Very Helpful" would be appreciated . .
Dec 06, 2009 | HP Photosmart R707 Digital Camera
Why wont my ipod touch turn on i turned it off and it wont come o
Hold the power button and home button for 10 seconds to ensure the device is off. Let go.
Hold the home button down, plug in the ipod to the computer, after the screen changes to the itunes plug screen, let go of the home button.
The ipod will now be in recovery mode, and you can attempt to perform a restore within itunes.
If the restore fails, and the ipod screen stays black, this means the battery is dead and must be replaced.
Oct 22, 2009 | Apple iPod touch
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Hp r707 wont turn on
Connect the charger. If the camera works while connected to the charger, you need a new battery.
Jan 02, 2009 | HP Photosmart R707 Digital Camera
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
HP R707
get the adapter plug it in,, in the camera that little hole next to the usb,,, just like u will charge the battery, then turn the camera on,, just your camera lens will be back to normal,, hope i helped ya out.
Sep 11, 2008 | HP Photosmart R707 Digital Camera
Kodak Z740, wont turn on!
plug it in dc power if you have a docking station the unplug the cord from the dock and into the camerea. regargable batteries only charge if the cameras sitting in a docking station
Oct 10, 2007 | Kodak EasyShare Z740 Digital Camera
Flash problem HP R707
I've just spent 30 minutes on the phone (premium rate) to HP re this problem. The solution was as follows: switch the camera off take the battery and any memory cards out press the end of a paperclip into a small hole (which you can see with the battery compartment open) remove the paperclip after 10 seconds put the battery and memory card back in and the problem should be sorted. HP also suggest upgrading the camera firmware (which you can do via their website)
Aug 10, 2006 | HP Photosmart R707 Digital Camera
HP Photosmart R707 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
