Question about Cannondale Capo
Do you know what bearings a 07 or 08 Capo rear wheel takes. It looks like 10x26x8. Any ideas
    Guru:
  • 347 Answers
Depends on what rear wheel you have. The spec changed on these bikes a few times throughout the the 2 years you mention. Need to know what rear hub you have.
You can take into any bike shop and they can tell you quickly with a visual inspection what bearings it needs. If you have cartridge bearings it will have a number like 6002 on the rubber seal, if they are standard round loose ball bearings than it will be a size like 1/4" for rear.
Posted on Apr 11, 2011
Bearing rear remove wheel
It would take me a couple of hours to write it all out. Best solution, get a service manual and read it as to the procedure. Follow the procedure step by step and you will have a very good idea of doing the task.
Mar 22, 2014 | 1992 Holden Barina
1994 LINCOLN CONTINENTAL
Hi Terry,
Please check out this Link : http://www.autopartswarehouse.com/featured/books_and_manuals/1461465620.html
Here you will find the details regarding your Car and how you can check and repair the breaks without taking it to a mechanic.
I hope this helps.....
Jun 02, 2008 | 1994 Lincoln Continental
I Currently have X9 10 speed rear, but need to replace jockey wheels. are these interchangable with X10 or XX?
Replacing jockey wheels is one of the easier tasks on a bike. You will two standard, 11 tooth jockey wheels. Investing in metal ones with ball bearings is a good idea. Use an aallen key to remove and replace one at a time, taking particular attention to the way the CHAIN goes around each jockey wheel.
Mar 16, 2013 | Sram X9 Crankset 2x10 w/Bash for GXP
Change wheels on my Capo or more resilient tyres, to reduce punctures.
I thing you shud keep the tyres and avoid pit falls
Apr 22, 2012 | Cannondale Capo
Rear wheel bearing hyundai coupe
just remove the wheel and count the teeth on the ring on the rear brake thats all you need to do. Since you can't drive it take it off and take it in to compare parts so you don't have to go back twice. You will need a new wheel seal and race and bearings.
Sep 29, 2009 | 2001 Hyundai Tiburon
How do i go about changing the rear bearings on my 2003 660 Raptor.
loosen both chain tensioners, remove big nut from shaft, lift rear wheel off ground on centerstand or blocks under frame.push wheel all the way forward, pop chain off. with aluminun drift, knock out wheel shaft (take note of any spacer and washer locations), remove wheel. with same aluminun rod, tap the bearings out, from the inside out. its agood idea to use new bearing seals too. put it all back together, same sequence as removed. dont forget to grease em up good
Jul 30, 2009 | 2004 Yamaha XT 660 R
How do i replace the rear wheel bearing on my peugeot 206 1.9hdi year 2002 my rear wheel bearing has gone on my pug206 and i want to know how to fix, replace and repair myself i have bought the rear wheel...
wheel off remove the tin cap in the centure of the hub undo the big nut put the wheel back on with just 2 bolts finger tight so you can pull the hub off.once the hub is off take the 2 wheel bolts back out.now look in side the hub were the big nut was and you will see a sir clip take that out.then use a socket and a bench vice to press the old bearing out.use the socket and bench vice to put the new bearing back in.
Jul 20, 2009 | Peugeot 206 Cars & Trucks
We are trying to replace my rear wheel bearing. Can anyone give any ideas how to get it apart?
here is how to replace it on a 2 wheel drive please do not forget to rate and comment about your experience today. 2-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Inner wheel bearing race from the hub
    • Snapring
    • Wheel bearing outer race from the knuckle
To install:
  1. Install or connect the following:
    • Wheel bearing in to the knuckle
    • Snapring
    • Wheel hub into the wheel bearing
    • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake drum
    • Rear wheel
Apr 11, 2009 | 2005 Ford Escape
Rubbing or grinding noise coming from Driver side rear tire/wheel
I had the same problem that based on interner research is common for Fords trcuks/suvs. The common problem fro rear humming "rubbing"sound might be the rear wheel bearings/seal. These will need to be replaced as it will progressivly get worse and the noise louder and eventually the bearings can sieze. I would hesitate to take to a ford dealer if I were you as it can run $500-900. Take to mechanic that knows how to replace wheel bearings and seals. My mechanic replaced them for about $150. and the bearing and seals are around $40. A good way to test this is to raise the wheel were you can freely spin by hand...if does not spin or there is a lot of friction then it might be the wheel bearings.
Good Luck
Apr 08, 2009 | 2002 Ford Explorer
Cannondale Capo Logo
187 people viewed this question
Top Cannondale Cycling Experts
John Egan
John Egan
dante
Tom Chichester
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
