Question about Dryers
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
I have a kenmore ultra fabric care heavy duty/soft heat 90 series dryer, model # 110.86984110 and I would like to know how to remove the old motor and replace it with a new motor (need to remove motor as I feel this one is fried also so I can figure out what motor to get) any help would be greatly appreciated.
  • 4 more comments
  • Marisa Marco Aug 18, 2008
    I need to remove and replace a kenmore dryer motor.
    How do I remove the motor?
  • Anonymous Nov 08, 2008
    dryer motor removal or disconnect from fan
  • Mike Durland
    Mike Durland May 11, 2010
    freon409 skipped the whole blower wheel removal procedure. but if you ask him i am sure he will help you with it.
  • Mike Durland
    also are familiar with taking apart dryers at all? like taking out the drum?
  • Mike Durland
    i just wanted to make sure you know that the motor costs $120-$180+ before we go any farther.
  • Anonymous Mar 14, 2014
    How to replace motor
  • 210 Answers
Remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Posted on Aug 07, 2008
I have a kenmore ultra fabric care heavy duty 90 series soft heat i will not come on hum not nothing
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Aug 28, 2011 | Dryers
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
Mar 25, 2010 | Kenmore Dryers
We have a Kenmore Ultra Fabric Care Heavy Duty 80 series. It won't heat up.
You probably have a faulty heating coil, or thermostats.
If you plan to repair it yourself, remove the back of the machine, locate the air tube going from the blower to the drum. Normally inside of the air tube is where you will find the heating coil, and thermostats.
Check your heating coil with a continuity meter across the two terminals.
Good luck,
I hope this helps
Oct 05, 2009 | Kenmore Dryers
I have a Kenmore/Ultra Fabric Care IV - Heavy
Sounds like the machine is stopping to me, could be the off balance switch at the rear off the machine. You should know if its getting to the spin cycle.How wet are your clothes ? Hope this Helps.
Sep 15, 2009 | Washing Machines
Kenmore dryer- remove fan to change motor on dryer.Do I need a gear puller to remove ? 7 yr old 90 series dryer ,seal drum came lose from damage to dryer when purchased. Did not relize damage until motor...
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
Mar 22, 2009 | Kenmore 659 Electric Dryer
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Dryers Logo
3,626 people viewed this question
Top Dryers Experts
