Question about LG WM-2277HW Front Load Washer
BOTTOM DRAIN HOSE LEAK
Is replacing the bottom drain hose on the wm-2277hw as simple disconnecting the hose clamps and replacing it? Is there any special precautions that need to be taken when replacing it?
  • chatabox Aug 15, 2008
    HOw do you replace the drain hose is there any manual for this?
  • 706 Answers
Http://136.166.4.200/contents/Laundry/WM2277.htm
Try that website and download the service manual..
Hope that helps...
Posted on Aug 17, 2008
Drain hose mesh filter on end of drain hose clogs
it is a drain hose so there is no need for a filter
the water to drain will be dirty so there is no point in filtering dirty water destined too go down the drain
Aug 21, 2017 | LG WM-2277HW Front Load Washer
How to remove waste hose from machine?
1 Turn off the circuit breaker that controls the dishwasher.
2 Open the dishwasher door. Locate the two small screws holding the bottom valance trim piece. Remove the screws and the valance, revealing the lower pump assembly and drain-hose connection.
3 Remove the hose clamp. Disconnect the drain line by pulling the hose.
4 Find the other end of the drain line under the sink; it is connected to the drain tail piece or the garbage disposal. Remove the hose clamp and disconnect the drain line. The dishwasher drain hose is now disconnected at both ends.
5 Pull the dishwasher drain hose into the sink base through the hole between the dishwasher and the sink base.
6 Take the dishwasher drain hose outside or to a wash sink. Run hot water through the line to clean and unclog it. When you see water running freely through the hose, then it is clean. If the hose cannot be cleaned, replace it with a new drain hose of the same size and length.
7 Feed the clean dishwasher drain hose back to its original configuration. Reconnect both hose clamps. Reinstall the valance, turn on the circuit breaker and test-run the dishwasher.
Nov 29, 2010 | Smeg CSU2001 Built-in Dishwasher
Washer leaks from bottom while filling. Leak water is sudsy. Appears to drain ok.
possible blockage with congelled soap under soap drawer intake,, look at the hose,,under soap box
Jun 21, 2010 | LG WM-2277HW Front Load Washer
Oe code, i need to clean the black hose on the bottom of the washer how do i do that. thanks
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | LG WM-2277HW Front Load Washer
I have a 2001 subaru outback and appears to be leaking coolant from thermostat but not having loss of heat yet. Can gasket be replaced or do you have to replace whole thermostat? Also where can I find...
This sounds most likely to be a lower radiator hose leak (very common). It may be just as simple as tightening the hose clamp holding the hose to the radiator. If tightening the clamp does not work, replace the hose. When replacing the hose you must first drain all the coolant from the radiator and engine. Once its all drained, loosen the hose clamps on the hose thats leaking, pull the hose off and replace it with a new one. Tighten down the hose clamps and add coolant.
Dec 30, 2009 | 2001 Subaru Outback
My washing machine is leaking from the bottom it is ruining my floor do I need to replace the machine or do you think it is a simple task to fix
If this is the same leak I just fixed, it is worth fixing ($12 dollar part from repairclinic.com), but takes some skill at taking it apart and putting it back together.
My leak was from a black rubber hose that connect the drum to the filter area and recirculating and drain pumps. The repair can be done from the front of the machine.
1. Drain the machine - pry the panel at the front left lower corner to get access to a stoppered tube. drain as much water from here as possible.
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right (there is a wire connecting the door to the machine on the right)
7. You can now see inside the machine and hopefully see where your leak is comming from. The black rubber hose connecting the drum to the drain area is where my leak developed because this is designed to flex as the machine tumbles and spins but ultimately wears out. It is connected with two clams that can be removed with pliers and a third hose clamp that diconnects with a phillips head screw driver.
Apr 26, 2009 | LG WM-2277HW Front Load Washer
Fisher Pakel 4 years old Water leak
possible its form the pmp assy underneath, youll need to tip unit back( the bottoms open, look for leaks, should be quite noticable
Feb 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water will not drain from tub.
Clean out the trap from the bottom, something is jamming the drain motor
Dec 22, 2008 | LG WM-2277HW Front Load Washer
Drain hose leak
Hi Krazytech here, You will have to remove the cabinet to get to the pump end of the drain hose. First you must remove the top insert a putty knife to open the top lift up then remove screws that hold on the top then remove the screws that hold on the bottom. then you can get to the pump I alway replace the factory spring clamps with a screw hose clamp they are much better.. let me know
Aug 24, 2007 | Maytag MAV7600 Top Load Washer
LG WM-2277HW Front Load Washer Logo
231 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
