Question about Samsung SpinPoint MT2 HM100UI 1TB 5400 RPM 8MB Cache 25 SATA 30Gbs Internal Notebook SATA II Hard Drive
Can samsung HM100UI hdd of 1TB support hp dv4 1227tx laptop?
2 Suggested Answers
  • 45 Answers
SOURCE: Hi, I have dropped my iOmega
If you remove the drive and connect it to a pc using the sata cables it could work if you only damaged the controler.
In my experience it is more likely the drive itself is damaged. If this happens and the read/write head or the magnetic store is physically damagedthe only way is to ask a data recovery company. The good news is that recovering a single drive is relatively cheap......
Posted on May 19, 2011
Samsung NP355E5 not boot from HDD.
You may find best results finding Samsung support for this at...
http://www.samsung.com/us/computer/pcs/NP355E5C-A01US-specs
If this, my reply helps, you may show that.
A
Jun 28, 2017 | Samsung Computers & Internet
Sir, Im having P4BP-MX Motherboard 2GB DDR 40 GB HDD, CAN I GO FOR 1TB HDD for my Motherboard. I bought 1TB its not identifying Is my P4BP-MX Motherboard support 1TB or Not ?
There's two things wrong:
1. You can't simply install a hard drive and then use it. You have to format it and/or install an operating system on it.
2. Your motherboard is a very old model. While it is new enough to support LBA48 mode (which is necessary to fully use hard drives above 127 GB), it is possible that it has an old BIOS version that does not support it. You should check ASUS' website to download and install the latest BIOS update.
Dec 11, 2014 | Samsung Computers & Internet
Hp hdd no show computer
Is this an external 1TB Hard Drive? Maybe it's to big for your computer. If it's an external drive try it on another computer and see if it works. There is also the possibility that the external 1TB drive is bad.
If it's not an external hard drive then try the steps below.
Click Start/My Computer and see if your hard drive is listed as a device. If not, turn the computer off, remove the battery, remove the cover that houses the hard drive on the bottom of the laptop then remove the hard drive from the bay. Wait 30 seconds and put the hard drive back into the bay and reboot. Now see if the hard drive is shown under My Computer. If not, the drive might be bad.
May 30, 2012 | Computers & Internet
I am trying to install my 1tb s2 samsung potable hard drive on my laptop but i wont install it
external HDD are plug and play devices and will be recognized automatically, the problem detecting large capacity drives like this relies on what type of hardware you are using (laptop itself). what I am trying to point is that old laptop only recognize lower capacity drives and thus have this issue.
but if you are using the latest hardwares and OS, just let me know so that i can pin point the problem.
Aug 27, 2011 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Hi, I have dropped my iOmega portable HDD. The actual drive inside the iOmega case is a Samsung 1TB HM100UI. Now when connecting power to the drive I get a sequence of beeps/sounds then nothing. The...
May 19, 2011 | Samsung Spinpoint MT2 HM100UI 1TB SATA...
My laptop Model Compaq 5204NR I want to extend my hardisk. Is it possible to use External Hardisk for this model laptop. If it means how much can i use 1TB hardisk or which is suitable for this laptop....
Yes you can use an external HDD to extend your current HDD. If by extend you mean use the external HDD for storage and such.
However if you wanted to literally extend your current HDD by creating a single partition for both HDDs then it could be extremely problematic because the external HDD will be connected with an USB cable. If you were to accidentally unplug the usb cable then your whole system would crash.
Feb 28, 2011 | HP Compaq Presario V5204nr Notebook
How to change a pcb board on a samsung hard drive
Remove the securing screws and gently unplug the ribbon cable. I do not advise doing this however, as even the same model of this drive may use a pcb board that is a different revision to yours
Jan 10, 2011 | Samsung SpinPoint MT2 HM100UI 1TB 5400 RPM...
I have a Toshiba 1tb external hdd (px1396-3t01) and when i connect it to my laptop i see a blue flashing light..The disc is not recognised by the laptop! what can i do..???????
How old is your laptop? Are you running at least Windows XP Service Pack 3? If so, Right-click My Computer, then left-click Manage\Storage\Disc Management. Do you see your 1TB HDD listed? If so, is it described as Unallocated Space. If it says that it's Unallocated, then right-click in the black area and choose format, then follow the prompts from there. You should probably format it as NTFS. Be careful not to accidentally format a drive other than your 1TB HDD. If you don't see your drive listed in Disc Management then double check your connections. If all is connected well, then you should probably return it to wherever you bought it.
Nov 30, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Samsung SpinPoint MT2 HM100UI 1TB 5400 RPM 8MB Cache 25 SATA 30Gbs Internal Notebook SATA II Hard Drive Logo
94 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
