Just got Haus HW50 1010S, have no manual, put it on pre-wash and was on for 6 hour! how do I stop the machine! apart from the obvious switching off the power which I have done several time and just goes on washing when put back on.
  • 6277 Answers
SOURCE: Our Haus hw50-1010w washing machine
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 03, 2011
SOURCE: I need a user manual for a HAus HW50-1010 Washing
http://www.manualowl.com/m/Haier/HW50-1010/Manual/180896
It seems that Argos recycled a brand called Haier (Chinese) and turned it into HAUS (German)!!
The washers are exactly the same. Manual is the same.
Posted on Nov 14, 2011
SOURCE: LG Intellowasher 7.2kg WD80130F
where is the drain filter located
Posted on Mar 11, 2008
SOURCE: hotpoint wma 50 flashing pre-wash
i had the same problem, the programmer inside the control panel had blown,
check the wiring hasnt pulled near the motor, sometimes an earth wire comes off apparently.
Posted on Feb 09, 2009
SOURCE: lost the installation manual for a haus wm1050w
where can i get a manual for the haus machine
Posted on Dec 28, 2009
Need instruction manual for Haus WM 1050w Washing Machine
(pre-typed!)
Sorry but FixYa cannot do that direct- members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
John C.
Aug 19, 2011 | Washing Machines
Flashing pre-wash approx 1 hour into wash cycle instead of moving onto rinse and wash. Whats causing this? This is happening on the WMA50.
Hi! If the pre-wash light flashes it means you are not getting enough water in the machine, check the pressure chamber, pressure switch, fill hoses and valves. For a workshop manual on the WMA50 which includes fault finding, visit www.selfix-uk.co.uk
Feb 17, 2011 | Hotpoint WMA50 Front Load Washer
My washing machine (HAUS WM1050 is full of water, it won't empty whatever cycle i put it on. How can i fix this??
Hi, i have a Haus WM1050s which is also full of water and will not drain. There is a cover at the front with NO filter behind it, just a large plastic screw (unsure what). I suspect the filter is blocked, does anyone know where it is before i pull the machine out please.
Thanks in advance
Alison :-)
Feb 10, 2011 | Washing Machines
I need a user manual for a HAus HW50-1010 Washing machine
Jul 13, 2010 | Washing Machines
Washing Machines Logo
235 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
