My 8G usb can't be detected by my computer, my flash drive was brought 3 months ago and only half of it was used
  • 32,281 Answers
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Posted on Apr 11, 2011
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
Kingston datatraveler 8G shows write protection error, contain a virus outorun.inf, cannot save, cannot be formated and cannot delete. Please help.
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
Jun 01, 2011 | Kingston Digital DataTraveler 4000 8 GB...
How to format my 8g cruzer micro USB
Go to my computer and right click on the USB Flash Drive then left click on format
Nov 30, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
USB drive does not regularly read the USB flash
I have a Designer I USB that suddenly started not reading the usb stick that came with the machine. I was terrified that my machine was going bad, but I always start with the cheapest solution first. I bought a new usb stick, loaded the designs from the old one into my software then loaded everything on the new usb stick. My machine reads it every time so far. I replaced the usb stick about 3 months ago and have not had another problem since. I don't know if this is your problem, but usb sticks can go bad and since they are so cheap, I would try this first.
Jul 11, 2010 | Husqvarna Designer I
Computer can't detect the flash drive
The use of USB on that different PC must have been disabled from the CMOS. Enable it by pressing Delete key upon booting to enter your cmos settings.
Jul 19, 2009 | SanDisk 2GB microSD Memory Card
Bought 500Gb two months ago,greatproduct.My wife has put 4 months of college photography on the hardrive and has had no problems retrieving.Suddenly two nights ago stopped working,power light is on...
Plug it into a friend's computer (in the same cables as his main drive) (Turn the system off and pull the plug out first!) Tell us if it works there.
Data loss happens all the time for various reasons. That's why you need to learn how to use a CD burning program to transfer the pictures to CD's. If you don't want to burn often, get yourself a 16GB little flash drive at least.
Mar 12, 2009 | Maxtor Hard Drive
PLEOMAX 5GB Thumbdrive
Do you see a message on your system tray when it is plugged in? If you don't see any message, it means that the drive is not being detected. You can't retrieve any data or files on the thumb drive if it is not detected. Things you can try to isolate the problem:
1. Try a different USB port on your computer. Check if your thumb drive will be detected.
2. Try a different USB device like mouse on your USB port. If it is detected, it means that the problem is the thumb drive. If not, it means that the USB port is not working or is disabled.
3. Try the thumb drive on a different computer.
Hope this helps. ;-)
Oct 17, 2008 | Samsung Pleomax Zirex UHD-8G USB Hard...
46 people viewed this question
jasbo
jasbo
