Question about Toshiba e-Studio163 Copier
How to set value 08 mode code 695 set value to 0
  • 132 Answers
Hi
Please switch of the machine.
While holding buttons [0+8] down, switch the macine on, when [ad] appears in the display remove the fingers.
Now key in [695] and press the start button, when [1] appears in the display input [0] and then press the interupt button.
[Ad] will then reappear in the display, now input [971] and press the start button, make sure that value is [3] and then press the interupt button.
Switch off the machine and then switch back on to take it out of the test mode.
Those two codes will disable the machine checking for toner.
Posted on Apr 11, 2011
How to solve the problem is toner signe in toshiba E studio 166
You can unable the control of the toner level.
You have to enter the 08 mode (press 0 and 8 keys simultaneos and turn the machine on), than enter code 695 than press start and than set the value to 0. Confirm the choise with enter key.
Nov 17, 2012 | Toshiba e-STUDIO166 Printer
Toshiba e-studio 255 add toner blinking after changing new catridge
did you shake toner cartridge really well... assuming that you have, was the copier allowed to run on 'fumes for a while before replacing Toner? if yes then switch off and back on a few times to allow the Toner levels back up to normal level... (replenish) if all that fails then you will have to call an engineer as it is possibly a faulty sensor on the DV unit.Steve (copier engineer 27years)
Mar 24, 2012 | Toshiba estudio 255 Copier
F14 erroe code
F14 indicates Invalid backup counter.
Download the counter value of the MAIN board to the SRAM board in
the setting mode (08-388)
Feb 12, 2012 | Toshiba E-Studio167 Copier
How to ready toner not recognized
Hello
Please switch off the machine, while holding down0+8 buttons switch the machine on.
When machine starts and displays [ad] input 695 and press the start button.
Input 0 and press interupt and energy saver.
Input 971 and make sure that value is 3, if it is not input 3 and then press interupt then energy saver buttons.
Switch off the machine, wait awhile then switch the machine on.
The problem should be sorted out,
Regards
Apr 16, 2011 | Toshiba E-Studio167 Copier
Kindly tell me how to remove toner sign after installed new toner cartrige and how to enter in sp mode. regards Muzammil
turn machine off hold down 0+8 keys and switch on inpuut 695 and press print if the value is 1 make it 0 if it is 0 make it 1 save it and check 08-971 is 3
Feb 15, 2011 | Toshiba e-Studio163 Copier
When start machine then display shows call for sevice F14
F14 Scanner unit FROM error
Was the main PWA replaced?
YES
Download the scanner total count value into the main PWA in the setting mode (08-388).
NO
Was the scanner unit or scanner control PWA replaced?
YES
Download the scanner total counter value of the main PWA into the scanner control PWA in the setting mode (08-389).
NO
1. Check if each connector between the scanner control PWA (CN6) and the main PWA (CN8)
is disconnected.
2. Check if each connector pin is removed or the harness is broken.
3. Check if any conductor pattern on the scanner control and main PWA is open- or shortcircuited.
4. Replace the scanner control PWA.
5. Replace the main PWA.
Nov 17, 2010 | Toshiba E-Studio167 Copier
Need service codes for this model
By default, after 74000 of PM counter, it will appear.
U can clear it if the machine is working fine.
Reset PM counter
08-252, set the value to '0'
To disable the PM counter,
08-212, set the value to '0'
May 06, 2009 | Toshiba e-STUDIO 282 Black and White...
Toshiba e-Studio163 Copier Logo
97 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
