Question about Yamaha DD55 7 Pad General MIDI Digital Drum System
Two of the pads on my Yamaha DD55c drum machine do not seem to be triggering properly. For example, if I hit the snare pad it seems to always be triggering at a low velocity, but if I strike it flat with the stick stretching the whole way across the pad, it will trigger at high velocity. The high tom pad barely works and is very tempremental. I have tried altering the velocity sensitivity, but this has made no difference. I think it is more to do with the actual triggering of the pads themselves. I was considering opening it up and seeing if there was something I could do to make them more sensitive. I did something similar with my "Guitar Hero" drum kit, when the snare started doing much the same. I solved the problem by using a lollipop stick across where the trigger was to help increase surface area and sensitivity. I do not know however if the same will be applicable to the DD55c. I thought I would seek advice before opening it up. Can you help? Thanks, Ryan.
  • Yamaha Master
  • 5,603 Answers
A weak snare is a characteristic of these... The triggers are typically piezo discs that were often used in musical cards but those have now gone to using very flat little speakers... You may find some have been dislodged or broken loose... worth a look inside.
Posted on Apr 11, 2011
I have a RMP-5 Rhythm Coach. I cannot get any sound from the pad when I practice. Help
Hi, after doing a bit of googling it occurs to me that the internal speaker is ONLY for the metronome / click & not for the drum sounds themselves. You will need headphones or some external audio gear like your hi-fi system or oth r amp & speaker. I found this "The pad has 54 sounds in it (covering all parts of the drum kit but mostly snares), which are triggered when you hit the mesh head, but these can only be heard over headphones. The built in speaker is only used by the metronome sound (when there are no headphones attached) and then it only has a beep sound attached to it. However, plug in headphones and you get a variety of available click sounds including a proper ticking clockwork metronome." Hope that helps a little? Good Luck :-)
Dec 07, 2014 | Roland RMP-5 Rhythm Coach
Yamaha dd55c hi hat foot pedal not working
This could be caused by a number of things.
1) Socket on DD55 could be broken
2) Cable could be broken
3) Plug at end of cable could be broken
4) Switch in foot unit could be broken
Eliminate each by working through 1 - 4 using a multimeter and then repair accordingly once you have found the fault.
Jun 30, 2014 | Yamaha DD55C 7-Pad General MIDI Digital...
I Have a Yamaha dd55c electronic drum machine without the bass and Hi-Hat pedals. I am good with electronics and wondered how they are wired, or alternatively if they are available to buy from anywhere.
The pedals are domes with Piezo disc sensors. SImple two wire connection... the original pedals are really NOT very good... You might try to find regular pedals used for drum sets... they have a beater and sensor. They do cost a bunch.
May 07, 2011 | Yamaha DD55C 7-Pad General MIDI Digital...
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
Mar 09, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
you need to determine what midi note the DTXplorer is using for the snare, kick and 3rd tom, and set the SR-18 accordingly, or vica-versa. the midi notes for each instrument has to be the same.
if you cannot change the midi note in either unit to make them correspond, you can download a "midi mapper" program (i think e-drum might be one), there is freeware available if you search CNet. with a midi mapper program, you would have to get a midi/usb adapter for your computer and rouite the midi signal through a computer. midi mapping software allows you to change the midi note, when the hardware itself is incapable of doing so.
Mar 09, 2011 | Yamaha DTXtreme III Drum Trigger Module
I had just recieved a brand new DM6. Upon setup the kick drum didin't seem to be working. I switched the cable going into the kick drum pad with the Tom 3 cable and the pad was responsive. When I...
THERE IS A TINY SWITCH ON THE BACK OF THE MODUELE
THAT MUST BE SET TO PAD , IF IT IS IN THE WRONG POSTION YOU WILL NOT GET ANY SOUND OUT OF YOUR KICK DRUM
Jan 12, 2011 | Alesis DM6 Electronic Drum Set
The base peddle sometimes doesnt register or goes off just a second after i press it. When no other pads are in use it works fine. Any advice on what i should do. Im experienced in electronics and im broke...
The bass pedals (domes) are really cheesy...consider getting a regular pedal/beater/sensor like they use on the electronic drum sets... that is what I am doing.
Nov 17, 2010 | Yamaha DD55C 7-Pad General MIDI Digital...
I have an electric triggered bass drum pad, and it will not trigger the sound through the machine unless I practically slam the pad the model is a KP65 bass drum pad, on a yahmaha DTXpressIV
Test the pad driving a different sound... If the pad is weak, the sensor probably came loose in it... They are a piezo disc usually like in older musical cards.
Some of the triggers have an adjustment pot that is very tender... ALSO there usually is a setting in the machine for sensitivity.
If this has just gone bad, it is likely the sensor came loose... repairable if one opens the pad...
May 24, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha DD55 7 Pad General MIDI Digital Drum System Logo
189 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
