Question about GE Washing Machines
Model-WHDSR316GOWN. Sounds like the drum is banging against the outer wall during wash cycle, not spin. Drum also seems to move too easily around the interior. Is there a bracket that may be broken? Is this an easy repair?
    President:
  • 2,468 Answers
3 things can do this,there is a shock absorber mounted from the "platform" assembly up to the tub cover on top of the tub that has become dislodged,broken,etc., also there is a "Spring/Suspension rod" also connected in the same manner that can do the same as above shock can,otherwise,there also are 4 "tub dampening straps" located around the top of the tub and they can break off the tub cover and aid in the first 2 issues,you need to remove the front cover by taking a flat blade/putty knife between the top and front cover near the sides and pop the clips holding the front panel on,then you can remove the lid-switch wires and remove the top cover to inspect all above possibilities
Posted on Apr 11, 2011
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
During a spin cycle what would cause the basket to be out of balance on every washload, even when there is not a balance issue. Basket acts loose and bangs against inside of machine
sounds like your bearings are excessively worn, open the machine door and hold the drum (stainless steel bit) try to lift this up if it moves freely without the tub moving (outer bit usually plastic or steel without holes) your bearings are gone. or the drum has broken off the wields that hold it to the shaft.
its sometimes cheaper to buy a new machine than repair the bearings and if the drum is loose it will eventually break something inside.
Jul 22, 2009 | GE Washing Machines
Banging noise on spin cycle
My beko washing machine was making a racket like this. What it was was the large blocks of concrete bolted to the drum had come loose. Solution was to get a 13mm socket with a bar and extension and tighten them up really hard as far as I could manage. THen the probelm dissapeared no more banging. Worth a try if your has similar blocks attached to outer drum
May 09, 2009 | Washing Machines
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Indesit widl 126-problem with the drum,moving back and forth to much and noisy.
It would seem that the bearings go on this model, which causes the inner drum to knock and bang against the outer during spin. If you continue to use the machine without replacing both sets of bearings, it will cause irreparable damage and the machine will need to be replaced.
Apr 27, 2008 | Indesit Washing Machines
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
89 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
