Question about Cell Phones
My telstra 6100a handsets cannot register to the bases. They are within the right distance, the batteries are charged. HELP
snakehead
  • 1074 Answers
SOURCE: Base won't charge handset
the base of your handset needs to be repair take it to a tech
Posted on Apr 04, 2007
  • 3 Answers
SOURCE: Handset not registering with base
You could try to clear all the memory from the base unit and start again!!!
Instructions to clear phone (Uniden 8855).
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
Posted on Feb 14, 2008
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
  • 5 Answers
SOURCE: How to clear all registrations from the base
One has to completely deregister all handset by pressing end and # keys together till complete de registration is shown on handset screen. if the de registration is not done as above stated method the hand set will not register will show connecting on hand set screen.
Posted on Nov 07, 2008
  • 7993 Answers
SOURCE: handsets do not register
Press the END button to exit or erase the message. Press Menu/Select. Scroll uo or down to find Register Base. Select the option, select it and put the handset in the charging cradle of the base. A confirmation beep will sound.
Posted on Jan 12, 2010
DS6321 out of range, no power at base
This sounds like a registration problem, the handset(s)
and the base have lost identification with each other.
I. To address this, first de-register the handset(s) ---
do this procedure for each handset:
0. Start by taking off the battery compartment cover....
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??", press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY (why the cover was off)
9. Wait ~30 seconds, re-connect the battery & replace the cover
10. display reads "Not Registered" ===============================
II. To register the handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
1. press [Find Handset] on the base and hold past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
May 02, 2016 | Vtech Lands Phones
3 of my 5 phones say "No Line"?
This sounds like a registration problem, the errant
handset(s) and the base have lost identification
with each other.
NOTE: the CS6429 works a maximum of 5
handsets, so you have a "fully populated system".
You will have to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ).
( I ). First de-register each handset ---
1. press [menu]
press [select]
(this is why the cover was off)
replace the cover
( II.) To clear the base of all handset registrations
blink. 2. release the [Find Handset] button momentarily,
ready for fresh registration ===============================
( III.) To register each handset to the base:
"Handset #x" or it will say "Registration Failed".
few hours and try the registration ( III ) again.
Good luck !!
Apr 16, 2016 | Vtech Accessory Handset with Caller ID for...
Have a replacement handset, base is cs6729-2 handset is cs6729-3 how do i set up new handset to see base?
This sounds like a registration problem, the new
handset must be de-registered from its original
base and then registered to your base.
NOTE: the CS6729 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
1. press [menu]
press [select]
replace the cover
( if needed, else skip ahead to ( III ). )
Good luck !!
Oct 29, 2015 | Vtech Lands Phones
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
1. press [menu]
press [select]
replace the cover
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
1. press [menu]
4. scroll from "Test Base" to "Test Handset", press [select]
press [select]
replace the cover
( III.) To register the cs6114 handset to the base:
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
Vtech cs6649 will not register more than one handset
The errant handsets must be de-registered from their
original base and then registered to your base.
NOTE: the CS6649 handles a maximum of only five
In that case, you can clear each handset ( I ) then clear
1. press [menu]
press [select]
replace the cover
Good luck !!
Jan 09, 2015 | Vtech Lands Phones
How do I register my vtech phone?
"Register" refers to the pairing of the handset to
the base so they can communicate securely
in private via an encryption scheme so no one
can easily evesdrop.
When you first set the phone up for use, you will
need to effect the registration then:
Good luck !!
Jan 03, 2015 | Vtech CS6829-26 2 Handset Answering System...
My phone displays out of range how to correct
This sounds like a registration problem. Try
de-registering the handset(s) and re-registering
to your base.
NOTE: the CS6429 handles a maximum of 5
1. press [menu]
press [select]
replace the cover
Good luck !!
Oct 02, 2014 | Vtech Accessory Handset with Caller ID for...
Vtech cordless handset CS6209 will not connect with CS6229-2 base
Yes. The'old' handset must be de-registered from its
1. press [menu]
press [select]
replace the cover
Good luck !! --
Jun 08, 2013 | Vtech Lands Phones
How can I register my GE 27911 handset?
I also had this problem and then I found a solution from another site.
Just open the handset and remove the battery for about 1 minute.
Reinstall the battery and go through the register procedure again - it will register almost immediately. just keep the handset near the base.
Jul 18, 2009 | Uniden Cordless Phone
Cell Phones Logo
77 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
