Question about Dishwashers
Hello i have a hobart autosoft glass washer, it just keeps filling up with water even when switched off. when its switched on it dose same. i dont know if it could be a vale in the plastic container where the water comes though on the back of the unit or if it is due to some thing on the circuit board. Cheers .
  • 112 Answers
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Posted on Oct 18, 2008
SOURCE: Hobart lx40 Dishwasher stopped working
the reason according me this to be happend,is a short circuit somewhere in the machine,it could be the heater,solenoid valve or to be caused by any leakage,you may check the fuse and replaced if necesary,and if that continue you need a technician.
Posted on Apr 19, 2009
  • 234 Answers
SOURCE: washer does not fill with water
The problem is most likely that your drain valve is defective. If this happens, the water will pump out instead of circulating. There may also be something stuck in the drain valve causing it to stay open.
If you need more help, post a comment.
Thanks,
Tim
Posted on May 29, 2009
  • 121 Answers
SOURCE: Our PLD4375RFC2 dishwasher fills up with water but doesn't run
no their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
Posted on Sep 17, 2009
  • 110 Answers
SOURCE: Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Posted on Jan 11, 2010
Hobart glass wash machine AMX-GH wash with normal temperature but do not advance to rinse cycle
Can you describe the sequence of operation?
Fill ok?
Booster or tank heating ok?
wash pump running ok?
Sep 28, 2016 | Hobart Underbar Glass Washer
Water level control switch not working. even i set water level to very low it just keeps filling and has overflowed. i am guessing that the switch needs to be replaced.
It depending on exactly what your seeing that will determine the problem.
Does your washer start agitating and keep filling?? if yes it does start agitating and the water continuies to fill try disconnectiing the power and if it keeps filling what would be wrong is that the water inlet valve is sticking open and it would need to replaced
If the washer continues to fill and does not start agaitating would be a defective water level switch as you suspect it may be.If ya disconnect the power and it STOPS filling replace the water level(pressure) switch.
GENE
Oct 02, 2011 | Kenmore 24032\24036 Top Load Washer
Model lxic keeps filling with water
If you have a problem with your washer or dishwasher continuing to fill with water after the valve has closed, then you this tip will help you understand why that is happening.
Here is a tip that will help you...
Washer or Dishwasher Fills with Water when off
heatman101
Apr 12, 2011 | Hobart Dishwashers
What kind of oil should I use in my Hobart 800 floor mixer? jdnwilk@juno.com
Hello Jdnwilk,
In a Hobart L800 you use 140 weight gear oil in the head and 90 weight gear oil in the planetary. You should start with about 160 ounces and check the sight glass and fill until in the middle of the site glass after oil settles.
Thank you for choosing FixYa.com
Mar 06, 2011 | Hobart Food Mixers
Water dose not stop runing and go into wash mode
Does your washer constantly attempt to fill and never does? Or, does the washer continue to fill and overflow?
If the washer is constantly trying to fill, but your water level does not change, you may have a condition known as siphoning. Siphoning occurs when you don't have a proper air gap on the drain line and the washer will actually drain as it attempts to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
If your washer fills, won't shut off and then overflows, this is caused by either a pressure switch malfuction, or a water inlet valve that won't shut off. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I know the link is for a problem where the washer continues to fill even when it is not in use, but this problem occurs while the washer is running as well. The method of determing the cause is the same. In many cases, an overflow problem is caused by the air hose slipping off the pressure switch. Without the air hose, the pressure switch never detects the pressure differntial from the wash tub as it fills and won't shut off.
Read through the links provided and let me know if you have any questions. If the conditions I have described do not match your symptoms, please post back and elaborate a bit more so I can help you determine the source of the problem. Please include your complete MODEL NUMBER. I hope you find this information helpful.
Mar 28, 2010 | Kenmore 24032\24036 Top Load Washer
Water level dont stop I bougth a new part and still have the same problem the water dont stop.
put the washer on cold,start to fill washer, turn washer off if water still keeps filling you have a bad water valve,do the same test on hot,if both turn off when you push stop then check the water level hose from the water level switch to the tub,if both ends are secure then replace the water level switch-mike
Feb 18, 2010 | Kenmore 22422 Top Load Washer
Jan 10, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
The code EO comes on after the thrid cycle on our Hobart glass washer what should I do
E0 STANDS FOR NO WATER @SUMP PROBE DURING 3 CONC. CYCLES. MY FIRST GUESS WOULD BE THERE IS SOMETHING STUCK IN YOUR DRAIN VALVE ALLOWING ALL THE WATER TO GET PUMPED OUT INSTEAD OF WASHING AND STAYING IN THE TANK. DONT FORGET TO VOTE
Oct 23, 2009 | Hobart LXiGC Dishwasher
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
