Question about Dell A215 Computer Speakers
I don't appear to have any connection between my computer and my speakers
    Sergeant:
    Champion:
  • 286 Answers
First of all, with no disrespect, have you got it in the right connection socket. If, yes, try getting new drivers. You should try driversguide.com or drivershq.com
Good luck. hope this helps.
Posted on Apr 15, 2011
Don't have sound
first of all did you plug your speakers into the green connection in your printer.. are your speakers on and the volume on your speakers turned on ?? I know this sounds stupid check these things first. then go into your control panel and choose sound and make sure the speakers are not on mute and turned up via the computer. sometimes there will be a speaker icon down where the time is on the left side on teh start bar
Jan 05, 2013 | Altec Lansing 220 Computer Speakers
Free hp drivers for speaker
how are these speakers connected to the computer? Via USB or via the 3.5mm port?
Usually you don't need drivers for speakers but what you need is the driver for your soundcard.
Hope this helps!
Sep 27, 2011 | HP JBL Platinum Computer Speakers
I need to connect my old speakers to my new Samsung monitor. No instructions in manual. thanks, barb
You don't connect speakers to the monitor, you connect it to the tower of the computer. If I'm not understanding your question right then please be more specific. If your monitor has speakers, you connect the audio cord to the tower then to the monitor or vise versa.
Jul 29, 2011 | Samsung Syncmaster 940BW LCD Monitor
The speakers were working the I believe I accidentally deleted the speaker software they don't even so as a device on the computer and aren't working??
The speaker you have mentioned is no need a software to use in a computer try to check if you are connected properly in your computer. See to it that you plug in the power adopter of your speaker and the input of the speaker is connected to the output of the audio of your computer.
Jul 19, 2011 | Dell A215 Computer Speakers
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
I can not find the drivers for Creative SBS 380
Hi lorenzogoode
You don't need drivers for these speakers : it's a plug and play system .
Check your connections , power supply and volume settings .
Best regards ,
fanaudi .
May 25, 2011 | Creative Labs Creative SBS 380 2.1...
My wife and I moved. I was in the hospital the week of moving. Others got us all moved. How do I get the NEC GMS2ONF speakers wired back? Two connected for one +power and one connect for the other? If...
You should have a cable that connects one speaker to the other directly. Then there's the power cable, and there should be another cable connecting the PC to the speakers.
Important: The PC's audio-output is usually marked with green color, that's where you should connect the cable going to the speakers.
Hope the above helps!
Mar 13, 2011 | NEC GMS20NF Speaker Computer Speakers
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
Dell A215 Computer Speakers Logo
18 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
Rick Davis
Rick Davis
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
