Question about HP LaserJet M1005 Printer
Scanner error 15 - HP LaserJet M1005 Printer
    Master:
  • 380 Answers
READ here on HP
http://h30434.www3.hp.com/t5/Scanning-Faxing-and-Copying/Error-0X00000015-The-scanner-is-not-ready/td-p/1106675
Posted on Nov 26, 2015
IN SCX 3201 PRINTER SCAN SENSER OUTPUT ERROR WHAT CAN I DO
With scanners and printers, the first step with an error is to turn off scanner/printer and computer. Wait 15 seconds, then turn on computer (but not scanner/printer) and if computer is ok, turn on scanner/printer and wait to warm up. Carry out a check-routine if you know how to. If all else fails, return here!
Bests, BigSteve
Dec 23, 2013 | Computers & Internet
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
Canon CanoScan 5000F Flatbed Scanner error 15. no manual.
Click on the link below to download the software, drivers, and owners manual for the Canon CanoScan 5000F Scanner:
http://www.cusa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_5000f
Oct 18, 2010 | Canon CanoScan 5000F Flatbed Scanner
I got E42 22 error code,it a scanner error,how do I fix it.
code 42 error definitely caused by loose flat cable from the scanner down into the electronics. End of the cable does not have a plug, just solder on each element, push the cable into its socket.
Jan 17, 2010 | Office Equipment & Supplies
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
Fujitsu 4860c scanner error
There are 2 sensors on the background unit(Front) SF1.5 and SF 2
Both sensors look like black boxes. SF2 is nearest the reading glass and SF1.5 is below it. Make sure both are clean. There are also tests you can run in test mode to recalibrate the sensors, if that doesn't work you have to replace it.
Apr 24, 2008 | Fujitsu FI-4860C2
Error code 15-380
15-380 means the exposure lamp in the scanner is not being senses.
Open the scanner and see if the lamp comes on.
If not, most likely the lamp has failed.
If it does come on, then the sensor or processor have failed.
Mar 19, 2008 | Xerox DocuColor 12 Printer
Symbol barcode scanner, handheld, cordless, yellow
error code communication error the scanner is not communicating with the cradle. It is important that the synapse cable is plugged into the cradle before the cradle power suply is pluged into a outlet. also could be the scanner did not pair up with the cradle correctly try rescanning the barcode on the cradle.
May 29, 2007 | Symbol Batch Barcode Scanner P360/460...
HP LaserJet M1005 Printer Logo
1,145 people viewed this question
Seeker5211
Seeker5211
