Question about Toshiba Satellite L455D-S5976 Notebook
Have a shaded line up and down on my monitor about the length and width of a standard ruler.
  • 1,179 Answers
The inverter needs to be replaced, or the screen needs to be replaced.
Claim warranty support if you can, the other option is to contact a laptop computer technician.
Glad I could be of assistance.
Thanking you
damnor01
Posted on Apr 11, 2011
How to get sq.inches? To measure quilt for cost
Multiple the length (inches) by the width (inches) = sq. inches.
Not quite sure what you attempting to do. Usually, a quilt is measured length for the length of the bed, and width for the width of the bed (and add any additional to drape down over the edge).
Mar 15, 2016 | Sewing Machines
Tip
Measure windows - easily and precisely
I always found it difficult to accurately measure windows with a tape measure, until I put a couple of sticks together. The sticks work great for measuring window widths for window shades or for ordering replacement windows. It is also perfect for finding a minimum width, because nothing in an old house is straight.
For measurements between about 26 and 42 inches you will need two straight pieces of wood approximately 1/4 x 3/4 x 24 inches. Round off one end on both pieces.
You can use a small clamp to lightly hold the pieces together. (Optionally, if you have a router table you can put slots in the two pieces to accomodate a bolt, nut and washers.)
Adjust the two pieces so that their combined length is just a little longer than the space you want to measure, and put only light pressure on the clamp or bolt. Twist the device through the space you are measuring so that the length of the device assumes the exact width you are measuring.
Do this in a couple of places (at the top, middle and botton of the window) to find the minimum width. Then tighten up the bolt (or clamp) just a little so it doesn't slip. Then measure the combined length of your sticks with a tape measure. This is amazingly precise.
on Feb 23, 2010 | Measuring Tools & Sensors
Bottom bracket size
probably 73x113
if you want to be sure, measure the width of the Bottom Bracket shell (on the frame) with a ruler, it will either be 68 or 73, but 73 is the standard for MTB.
if you are using the original single speed crank, 113 will work fine. if you are adding gears you will need something wider.
Oct 26, 2012 | Bianchi S.A.S.S.
Printer t2280+ displays paper width error after printind only one line and stop . even on selftest without connecting to the system
Hello
When using the Show method of Data Report to preview the report, the page orientation defaults to the default printer settings on the local computer. Therefore, if the orientation of the default printer settings is set to Portrait of standard Letter paper and your report width is more than 8.5 inches wide, the following error occurs:
1. Make sure that there is no extra white space in the report. If there is any extra white space in the report, close up that section so that the ruler falls within the width of your default printer.
2. Set your Left Margin and Right Margin to 0.
3. Check your printer setting to ensure that your default printer is set up correctly. If the report is landscape (that is, greater than 8.5 inches) the default printer should be set accordingly.
Jun 29, 2011 | Office Equipment & Supplies
I need a leather band for my male cartier roadster
mcdevito75 here, Ebay is your best bet for the Leather band for your Cartier watch, but! you:ll need to know the MM size of the band. Measure the width of the band just as it hooks onto your watch, use a ruler, most rulers have both the MM scale and American, if your ruler has only the American mmeasurement use the online Standard to MM calculator for the MM size from the American or standard measurement. Carefully measure the width of the band just as it hooks onto the watch, count the segments in the ruler either each MM or each 16 th of an inch, convert to MM then look on ebay for the strap.
Aug 28, 2010 | Cartier Roadster W62016V3 Wrist Watch
How long is 10 mm
10mm is a Metric measurement. If you go to a stationery shop, look for a school ruler it wld tell you 10mm = 1cm and 25.4mm wld be 1 inch. Or you can use your little finger's nail as approx size.
Apr 01, 2010 | Acme United Corporation 12in Ruler - 12"...
Problems about areas
Let x = the width of the women's court. Then 2x is the length of the women's court.
the area of the womens court is x times 2x = 2x^2
the length of the mens court is 4 ft longer than the women's or 2x + 4
The width of the men's court is 5 ft wider than the womwn's or x + 5
The are of the mens court is 650 square feet larger that the womens so we have to add 650 to the area of the womens court so the men's and women's will be equal
Now we have area of the women's court = area of the men's court
2x^2 + 650 = (x + 5) (2x + 4) = 2x^2 + 14x + 20
The x^2 cancel out and we are left with 14X + 20 + 650 solving for x we get x = 45
Plugging x back into the length and width equations we get the length is 94 and the width is 50
Hope this helped
Good luck Loringh
Oct 03, 2008 | Computers & Internet
Area and perimeter
Area= width * length
Perimeter= 2 * width + 2* length
Are you looking for an Excel function?
There are no Area or Perimeter functions I am aware of in Excel.
Mar 03, 2008 | Microsoft Office Standard for PC
Toshiba Satellite L455D-S5976 Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
