Question about Rowenta Irons
Iron does not cut on I believe i need a new cord. i live in Buffalo NY. any suggerstions for repair?
  • 17,130 Answers
Before this is confirmed please have the continuity of the cord checked , Only if the cord is open at the ends from the plug point to the iron terminals must you change the cord. If there is no continuity to the coils then the coil or the thermostat is open.
This can be checked easily with a multimeter.
Posted on Apr 11, 2011
The iron is no longer heating up, the power button is not lighting up. What is the solution?
broken cord at the plug or iron
control in iron faulty
repairs other than a cord will be more than a new iron
May 27, 2016 | Kenwood Irons
Replace cord in Rowenta Iron
0) Unplug the iron.
1) Remove the (2 or more) screws holding the plastic bottom plate (that the iron stands up on).
The screws are likely to be #20 Torx "Security" screws -- for which you will need a special bit for your nut/screwdriver. A kit of various sizes of Torx security bits will cost you about $10.
2) Remove the plastic cord-holder assembly from the iron.
2a) If the cord-holder is held in place with screws (you are in luck!), simply unscrew them. If you see no screws, then it is being held in place by several (probably 4) plastic tabs that you must simultaneously release. This makes the job much more fiddly. Use a small/medium blade screwdriver to carefully bend and hold each of the plastic tabs out of the way of the latches. You'll need one screwdriver per tab/latch! Take care not to break the tabs...
2b) Carefully wiggle/pull/work the cord-holder assembly out of the iron taking care not to bend the pins of the integral plug (inside the iron) that are seated in the cord-holder socket. Basically, with the iron resting on its metal surface, pull/pry/wiggle the cord-holder straight upward until the cord-holder (socket) pulls free of the (3 or more) stiff wires that function as a "plug".
3) Note that there are 2 crimp-on connectors attaching the 2 wires of the cord to the rest of the wires in the iron. Take a photo of the wires and jot down notes of which wires are connected together. NOTE: One of the cord wires is "neutral" and is attached to the wider spade at the plug end of the cord. Typically the "neutral" wire is marked with a white stripe or ridge down length of the cord. Don't mix up the "neutral" wire and the "hot" wire when you re-connect them in a later step!
4) Cut off the crimp-on connectors and separate all the wires.
5) Remove the cord from the system of zig-zagging "strain-relief" notches that hold the cord securely in place. You may have to remove a small plastic clip first.
6) Cut off 6 inches of the cord. (Or supply a new cord, if the cord has been shortened too much in previous repairs.) This eliminates the broken section wire within the cord. You may use an ohm meter to verify that both wires have a low resistance again (less than 1 ohm).
7) Route the cord back into the "strain-relief" notches in the cord-holder. Don't forget the plastic clip (if there was one)...
8) Strip all wires, exposing about 3/8" of copper on each.
9) Referring to your notes and photo, re-connect all wires using proper-sized plastic wire-nuts for secure connections.
10) Re-attach the cord-holder to the iron body. Make sure you line up the stiff wire pins with the cord-holder socket. Push the cord-holder into place and secure it (via screws or snap-in-place plastic tabs).
11) Replace the plastic cover, taking care to position the wire-nuts and wires to allow it to drop into place without forcing it. Secure the cover with screws.
12) Plug in the iron and test it out!
Mar 23, 2014 | Rowenta Irons
My Pro Finish 714 cord was accidentally cut. Is it worth replacing the cord? Where do you get a new cord and can I replace it myself?
Thank you for using FixYa. Is the cord cut near the iron end or the outlet end? could the cord be shortened? A new cord can be purchased at most reasonable hardware stores and with a little care and attention can be replaced yourself.
Hope this has been of some help.
Mar 04, 2011 | Black & Decker ProFinish X750 Iron
Display light does not stay on when I begin to iron; The #1 acrylic flashes off and on when the light is on.
Depending on the models, most irons only have the light on when its heating up and when the thermostart switches off it cut off power and hence the light goes off.
Jan 13, 2011 | Black & Decker D2030 Iron
Was using my Shark x-tended steamburst Euro-pro iron G1490 and it turned off and won't turn on
I had the same problem. The repair took less than 15 min. I opened the bottom of the iron and discovered what appears to be a design flaw on the cord holder/fastener. The holder is wedged so tight that it pinched the cord wire almost in half. I removed the cord, cut it off at the pinched spot and reinstalled. I also put a small piece of rubber onto the part of the holder that is made onto the body of the iron. In addition, I rotated the fastener cap so that the smooth side of it is against the cord.
Jan 12, 2011 | Euro-Pro Shark GI490 Iron
My iron went nuts and got way to hot. I shut off and the next morning it would not heat up. What to do?
I would say you throw it away and buy a new one. The heating element probably shorted out, overheated and is burned out. Too expensive and not worth the effort to repair.....
Dec 03, 2010 | Black & Decker D2030 Iron
I have a shortage in my cord and my iron cuts off when the cord moves not all the time but enough to frustrate me. I love my iron. So how do I get it repaired? the shortage is in the top of the cord not...
Take the cord out, cutoff the bad part and reattach...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 20, 2010 | Euro-Pro Shark GI490 Iron
The iron wont turn on
if the cord is broken get anew one,
  1. cut of the part that is broken
  2. attache the wires in this order
  • red to red or brown {live}
  • black to blue{nuetral}
  • and green to green or yellow or yellow/green [earth]
Apr 28, 2010 | Rowenta Power Duo Iron
Iron requires new cord
I don't know what brand of iron you have, but most irons are not repairable. I work for Black & Decker and if you needed a new cord for one of our irons, you'd have to replace the iron.
Unless you paid a small fortune for your iron ($100+) and you can see where the cord on your iron is able to be pulled out without taking the iron apart, chances are you'll have to purchase a new iron.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 14, 2009 | Irons
Irons Logo
52 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
