Question about Fujitsu Siemens SCENIC N600 PC Desktop
I am having a fujitsu pc and with windows xp recently i loaded some realtech for volume i am getting one error message but i can not avoid it the message is as follows: WINDOWS - NO DISK exception processing message C0000013 parameter 75b6bf7c 4 75b6bf7c 75b6bf7c cancel try again and ignore when i press one of these three the message goes but again and again appearing how to delete this message completely
Noggin
  • 944 Answers
SOURCE: Radeon FSC Graphics Display Driver
Go to this link armed with your exact model number(if you can't find this in windows device manager then easiest is to look on the card itself - unplug the pc first and don't touch anything inside unless you know what you are doing) then you can download the correct driver for your operating system if the card is compatible. Follow the download and install instructions and you should fix the issue. http://support.ati.com/ics/support/default.asp?deptID=894 If you need more help with this then please post again with your ati model number and your operating system version. Hope this helps :)
Posted on Mar 18, 2007
PcExpert
  • 293 Answers
SOURCE: Windows can't find driver for FI-5660C
THE PROPER WAY ON INSTALLING USB DEVICES 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Posted on Sep 19, 2007
  • 4 Answers
SOURCE: Fujitsu Sacaleo 600 boot problems
sallyb
Your registry is needs fixing.
PC's today get cluttered with more damaging data, junk, and extra files than ever. This results in poor PC performance, frequent system crashes, slow Internet connections and worse. Fortunately there are some great software downloads that you can use to fix things.
You can do two things.
1. download a registry fixer, which would be difficult for you to do since your system cannot restart.
OR
2. Reinstall your operating system. restart your computer and while it is restarting hold down the delete button. It will bring up your bios. there you can then go into your c-mos setup and change your boot settings to BOOT FROM CD FIRST. THEN HARD DRIVE..
When you finish that, press F10 to exit and save settings.
Ten insert your windows disk and restart system. Reformat the entire drive. (NOTE: YOU WILL LOSE YOUR INFO). OR you can tell it to repair .
My advise to you is when it is finish repairin. backup all your important files and follow step 2 but this time you would want to reformat the Hard Drive. (that is to wipe it clean and reinstall windows fresh.
Please let me know if this help.
Posted on Nov 16, 2007
  • 125 Answers
SOURCE: pc won't boot
You will need to run the restore cd or windows cd and try and retsore system, otherwise a clean format and reinstallation of intire windows.
Posted on Aug 14, 2008
SOURCE: Hello, i have a Fujitsu
GET A NEW COMUTER.
Posted on Jan 10, 2009
WINDOWS ERROR MESSAGE
boot from the CD copy of your windows XP. enter in console session and manually replace the file. if the file is corrupted this should fix it
Feb 26, 2012 | Gateway GT5026E PC Desktop
Realtek ALC888S device shows up twice, driver works only once
question, does your pc have realtech audio built into the motherboard or other like nvidia or ati. if not realtech then you are loading the wrong drivers. uninstall the realtech drivers and check under device manager to find out the device you need drivers for.. then download them from freeware files.com and install the correct drivers..
Nov 23, 2009 | Computers & Internet
Fujitsu siemens an unexpected I/O error has occured
Hello olamideidowu,
Here is a way to find out what the message means. Look for entries in the system event log that happened on the same day your error message happened.
*Using the Event Viewer:
•Click the Start button on lower left corner of the screen
•Select 'Run' (on Windows XP) or Type 'Run' and press the Enter key (on Windows Vista)
•Type 'Eventvwr' (in the 'Run' box) and click OK.
•(On Windows Vista) open the Windows Logs folder in the left pane
•Select the 'System' log in the left pane
•Look at the system events that happened on the same day as the I/O error. One (or more) of those events should contain the 'unexpected I/O error' message.
•Get the Event ID and look up what it means on the Microsoft Events and Errors Message Center: http://www.microsoft.com/technet/support/ee/ee_advanced.aspx
Also, the 'Message Level' of the event shows as Information, Warning, Error or Critical. Looking at the message level can help determine how serious the event may be. Events that have Error or Critical message levels can indicate a problem on the system.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 05, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
I am unable to install realtek hd audio driver in wipro pc model wsg15055 .every time message comes installation faied
hi,
If you are using windows xp service pack 2 then you need to install MSUAA first.
You can get it by searching MSUAA.
Otherwise please download the realtech driver from http://snipurl.com/zfpg
Jul 14, 2009 | Dell Latitude D600 Notebook
Please solve My problem-fujitsu V1020 Lifebook formated Vista then setup windows XP P2. sound detect but show message Error Code and PCI not detect.help me please.thanks
you cant able to the vista sound to xp the driver the company will give you only vista driver cd so get the sound drive for xp - download more than 3 diffrent sound driver for your pci slot realtec audio from internet and install it and it may works.
Jun 10, 2009 | Fujitsu LifeBook Notebook
Install realtech audio driver \ failure error code OXE000227
that sounds pretty ***. maby you should stick to game boys or super nintendos, sumthing **** like that :)
Jan 16, 2009 | Audio Players & Recorders
Fujitsu U810 problem ( not booting )
that means that you need to repair it in order to get the laptop back to its normal condition insert windows xp disc and repair the system that's what i think
Nov 28, 2008 | Fujitsu LifeBook U810 Mini-Notebook ...
PROBLEM WITH ACCESSING WINDOWS IE ERROR MESSAGE SAYING DLLS NEEDED
you'll need to boot from installation cd, and see if you can get to Safe Mode(F8)
Mar 09, 2008 | Computers & Internet
Fujitsu Siemens SCENIC N600 PC Desktop Logo
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
