Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool washer stops during cycle
Have a whirlpool washer model munber 110.47532602 i can start it and sometimes it will go through the whole cycle but sometimes during the cycle it will stop and a code
F28 will show up on the display panel, what is wrong with my washer.
i bought the washer mew in december. please let me know
  • 3 Answers
Do a visual inspection on the electronic module. To do you need to removed it. Follow the manual for this. I got the manual from, it's pretty big, about 44MB:$FILE/WPWASHER1.pdf
I had the same kind of issue on mine, no spinning and occasionally it did not want to start. I decided to remove "electronic control module" and do quick visual inspection on the board.
I find out that the board was full of little (microscopic) lead (plumb). I cleaned it with a toothbrush and ALCOHOL on both side, re-installed it and since then the machine worked find... Finally after a year I have a working machine.
I think you should test this solution before spending $400 on a new "electronic control module".
Let others know if it work on your side too.
Posted on Nov 17, 2008
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ... > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Leaking water washing machine -lxr9245eq1
sounds like a levelin problem check it in both directions and post back, also post model number TY
Apr 06, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool LHW0050PQ Front Load Washer Logo
338 people viewed this question
Dan Webster
Dan Webster
Sal De
