Question about Hitachi 46F510 46" Projection HDTV
Blue shading border 50in rear proj how to fix
  • 10,594 Answers
As question shows it is Hitachi 46F510 rear projection tv and blue shade border problem is related to convergence output section. Please try to adjust convergence as option would be available in tv Menu and if that does not help then it is hardware problem like convergence output chips going bad or dry/ cold solder joint developed in that circuit area etc.
This is job of tv technician to do solder work in convergence output section of tv to solve the blue border issue in picture.
Hope these info will help, let me know if there is additional question.
Thanks.
Posted on Apr 11, 2011
I have everything in blue. All colors are a shade of blue. The picture is bright clear but everything is shaded blue. Tried new HDMI and new sources but still every thing is in the blue spectrum. ...
The LCD chips in your TV set burned out the only one working is the blue chip that is the reason everything is that color.
You need to replace the optical block in that TV set to fix the problem.
This part runs from $150.00 - $250.00
I hope my answer was helpful :)
Oct 09, 2013 | Panasonic PT-60LC14 60" Rear Projection...
Border in each column
Follow this steps to achieve that.
  1. Click on the column you want to have a border, On the Page Layout menu click Borders
  2. On the Borders and Shading window go to the Borders tab not the Page Border tab
  3. Select the borders you prefer then on the Apply to: drop down select Paragraph. Click ok then your done.
May 12, 2010 | Microsoft Windows XP Professional
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
Blue and yellow shades
That problem is due to failure of convergence section in TV, you need to check convergence out section in TV to fix that problem.
Jul 18, 2009 | Sony KP-53V75 53" Rear Projection...
Green and pink shadow on my samsung 55in proj tv what can i do to fix it. i all ready fixed red and blue line but green is way off and i dont see any way to fix it
hi, this is the early signs of convergence board chip failure. you will need to replace this board in order to correct the collaboration feature. the convergence is responsible for regulating the RGB stream in you set. if it is malfunctioning, you will not be able to regulate the red blue green streams.
May 16, 2009 | Samsung HCL5515W 55" Rear Projection...
Kyocera fs-1030d wont print frames on MSWORD2000
wrong... the kyocera only prints what you send to it... you need to go into your print settings and make the adjustments so it can print frames borders/ shadings... this has been my experience with explorer and photoshop... not very much fun but necessary...
Mar 06, 2009 | Kyocera Mita FS-1030D Laser Printer
Mitsubishi rear proj 1997 model 45-50in
It's a 1997 TV, I recommend buying a new one. If you have to get it repaired it will cost you more than the TV is worth.
Mar 09, 2008 | Neovo AG AG-01 TV Tuner Picture Frame...
C Color is way outta wack on my 56 inch pilips rear proj tv. HELP
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Philips 60PP9352 60" Rear Projection...
Hitachi 46F510 46" Projection HDTV Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
