I need the driver i"almrnt5.dll" and " rtk HDAud.sys."
    Master:
  • 341 Answers
Down load the audio driver at: http://www.techpowerup.com/downloads/149/Realtek_HD_Audio_Driver_v1.66.html and the almrnt5 from:http://www.nodevice.com/dll/ialmrnt5_dll/item8161.html
Posted on Apr 11, 2011
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
Mtp function problem
Samsung MTP function Problem Solution It really worked for me.
1.)first copy umdf.exe from "wmp11-windowsxp-x86-enu.exe" to your Desktop, two methods:
a)unpack wmp11-windowsxp-x86-enu.exe(ex:with TotalCommander->Alt+F9) and copy umdf.exe to your Desktop
b)run the wmp11-windowsxp-x86-enu.exe(if you run it will extract the %TEMP% folder)
Click Start -> Run -> %temp% [ENTER]
Press F3 and search for "umdf.exe"
Copy this file to your Desktop
Cancel the WMP11 Setup
2.)Rename the folowing files, just copy&paste into your Command Prompt:
rename C:\WINDOWS\system32\drivers\wudfrd.sys test_wudfrd.sys
rename C:\WINDOWS\system32\drivers\wudfpf.sys test_wudfpf.sys
rename C:\WINDOWS\system32\wudfhost.exe test_wudfhost.exe
rename C:\WINDOWS\system32\wudfsvc.dll test_wudfsvc.dll
rename C:\WINDOWS\system32\wudfx.dll test_wudfx.dll
rename C:\WINDOWS\system32\wudfplatform.dll test_wudfplatform.dll
rename C:\WINDOWS\system32\wudfcoinstaller.dll test_wudfcoinstaller.dll [ENTER]
3.) Now run the umdf.exe and re-install it. After it's finished connect your phone and your MTP problem is solved.
Oct 24, 2010 | Cell Phones
HOW TO REMOVE THE ROOTKIT.TDSS caused by the Trojan virsus
Hi, You have to remove these to get rid of this Rootkit. This post is for an Advanced User Only!
Files and Processes:
  • Files which spread the Virus:
  • RkLYLyoM.exe, podmena.exe, file.exe, ~.exe, 7-v3av.exe, csrssc.exe (note that this is not CSRSS.EXE), 72631899.exe, 1776260179.exe, ucxmykkc.exe.
  • The above files will create processes and run while spreading the Virus and providing Backdoors to your machine as well as performing Remote Attacks on Servers.
  • This Rootkit and associated Trojan creates .sys (system files) to alter network configurations as well.
  • Delete these files.
  • _VOIDd.sys, _VOID[random].sys, UAC[random].sys, UACyylfjdaa.dll, TDSSnrsr.dll, TDSSmaxt.sys, tdssserf.dll, TDSSriqp.dll, TDSSciou.dll, TDSSoexh.dll, tdidrv2.sys, RkLYLyoM.exe, podmena.exe, tdssserv.sys, file.exe, ~.exe, 7-v3av.exe, csrssc.exe, 72631899.exe, 1776260179.exe, ucxmykkc.exe
  • Each variant of this is associated with one or more files in the above list. It drops .dll (dynamic link library files) as well. Dll files and Sys files are the actual performers in the background.
  • You have to remove these files from the startup as well. Using msconfig. From their you may be able to find additional files associated with this one as well. Verify by browsing. Browse by the file name. If you found that it is a virus, note the path and next time you will be able to remove it. I ll provide instructions at the bottom of this post.
  • Directories:
  • C:\WINDOWS\_VOID[random]\
  • Delete this as well.
  • Delete Registry values Associated with this.
  • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\_VOIDd.sys
  • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\_VOID[random]
  • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UACd.sys
Note: Random means the file name will be different for each instance.
  • Unregistering DLL files. The most important one.
  • You have to unregister these .dll files.
  • UACyylfjdaa.dll, TDSSnrsr.dll, tdssserf.dll, TDSSriqp.dll, TDSSciou.dll, TDSSoexh.dll.
  • The unregistering instruction will be provided at the bottom of this post.
You must delete your Temporary internet Files and Local Settings \ Temp. Located - Root:\Documents and Settings\[Admin account name - this may be either Administrator or any other account which has Admin Rights]\Local Settings\Temp. Note: Root is the Partition which has Windows Installed (Example C drive)
You must be able to see Hidden Files and Folders. Follow the steps...
You must clean your Browser Cache using Internet Options. Each and every browser has a place to clear the Cache. As an example "Google Chrome has it under Options -> Under the Hood -> Clear Browsing Data. Its better if you can disable Local Caching.
I recommend to do this in Safemode. Use F8 after restarting the machine. The select Safemode. Note: You may or may not find Processes associated with this RK however because they will not be loaded. If so you can use msconfig to locate "Startup" programs.
After everything done, flush your DNS. Get a Command Prompt (Start -> Run -> Type cmd.exe and hit Enter) Type this command and hit Enter. ipconfig/ flushdns
Contd...Post is too long...
Jul 13, 2010 | Dell Microsoft Windows XP Home Edition
How to install audio driver s71216xp?
Uninstall the old driver from device manager. Use the Add Hardware from Control Panel and choose 'Install from a specific location' click next. Use the browse button to point to the .inf file
May 07, 2009 | ASUS P4S333-M (P4S333-M SA/LAN)...
Ethernet Drivers (slow internet access)?
the fastest speed is the slowest path on the network.
right click on the my network place.
right click on the NIC local connection
click on configuration at the right of the connect using (NIC)
second tab, "advanced" check the speed & duplex- it should be auto, but you can change it. do not recommend it.
check resources- make sure it has no conflect with any other device.
if that doesn't help. uninstall the NIC driver and try to find a older driver. Sometime that works better, don't ask me, but it works.
Oct 30, 2008 | Gigabyte GA-M59SLI-S5 Motherboard
Kstvtune.ax
ALCXWDM.SYS
portcls.sys
ksxbar.ax
kswdmcap.ax
vidcap.ax
vfwwdm32.dll
CCDECODE.sys
NABTSFEC.sys
WSTCODEC.SYS
ipsink.ax
MSTEE.sys
isapnp.sys
usbuhci.sys
usbuhci.sys
stream.sys
wdmaud.drv
ks.sys
ksproxy.ax
drmk.sys
ksuser.dll
I can't install my multimedia as these files are missing. I tried reinstalling the drivers but it needed these files which I can't download even after I have inserted the Windows XP Cd. Can you please help me with this also let me know how I can download these files from the net.
Jun 02, 2008 | Microsoft Windows XP Professional With...
Samsung Q35 - sound does not work
Do you have any newly installed software? you might do the F8 and do the last good working configurations
Apr 21, 2008 | Computers & Internet
I need help
Download CDRom.sys or autorunGUI.dll For Free From www.afreedll.com or www.dll-files.com
And Replace The Cdrom.sys into The Windows Folder/System32/drivers/
And AutorunGUI.dll Into The Windows Folder/System32 /
OverWrite The Files If They Ask To Be Overwrited.
Good Day . email : arjunmanoj23@hotmail.com
Jan 10, 2008 | Pioneer Slim 4x ATAPI (DVRK12RA)...
Open Questions:
For Any Kind Of Toshiba Laptop Problems Call Our Toll Free Number +1888784-9316 As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Call Toshiba Online remote support service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Jul 20, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
