Question about Acer Aspire One D250 (99802378332) Netbook
I have an acer aspire one .The problem is that it's battery dfoesn't get charged over 75% even after prolonged charging.
  • Arhamajaz Apr 11, 2011
    How can that help explain please
    Problem Solver:
  • 7 Answers
You have to charge 100 percetn battery for very first time in case u dont ur battery wont charge fullly after that for example if u charge uor battery 75 percent first time and then discharge it without charging it cpmpletely then from ownward it could never be 100 percent charge. as a soliution put ur battry in sun light for more than six hour hope it would work best of luck
sory for bad English
Posted on Apr 11, 2011
  • 1,179 Answers
This shows that the battery is not healthy enough to accept 100% charge and is only healthy enough to accept 75%.
The solution is to claim warranty support on the basis of a faulty battery, if you have not had it long.
The alternative option is to purchase a replacement battery, you may even get one that holds more charge. A 6cell will enable you to use your laptop longer than that of a 3cell.
Thanking you
damnor01
  • 1 more comment
  • damnor01
    damnor01 Apr 11, 2011
    Sunlight is not good for the battery, it will simply warm up and could leak.
    Rather purchase a new battery or claim warranty support.
    Thanking you
    damnor01
  • damnor01
    damnor01 Apr 13, 2011
    Be sure to rate this session, Thanks damnor01
  • damnor01
    damnor01 Apr 19, 2011
    How did it go, any joy?
    Thanks
    damnor01
Model: Acer Aspire E1-571 The battery had
The battery may have failed even though new.
Apr 24, 2017 | Acer Aspire E1-571-6650 Laptop
Acer aspire 5935g battery problem
Many users do not use their notebook/notebook batteries correctly. The battery in a laptop/notebook/netbook is a rechargeable battery, like the battery in a Cellphone, a Digital Camera an eReader or an MP3/MP4/MP5 Player. This type of battery needs to both charge and discharge, if it is to perform to its maximum capacity and have a full, long life.
You would never dream of using a Cellphone, Digital Camera, an eReader or an MP3/MP4/MP5 Player only with the devices permanently connected to the mains electricity, because they are all devices that are designed to be used while the user is moving around whether indoors or outdoors, powered by their rechargeable batteries. the batteries of such devices are only recharged when the charge in their cells is depleted and then only for as long as it takes to restore full charge to them.
As with the other devices mentioned, a laptop/notebook/netbook's battery is designed for mobile use and the user should charge it to 100% full and then stop charging it to then use the device on battery power alone, until the battery is low on power, when the recharging cycle can then be repeated.
A notebook/netbook has more flexibility than the other devices mentioned because, unlike the other devices, it can also be powered directly from the mains electricity, without the battery installed.
If your laptop/notebook/netbook is mainly used away from the home or office, it is fine to leave the battery permanently installed. If, however, it is mainly used indoors at home or at work and always or almost always on exactly the same desk or table, then it makes little sense to use it either on battery power alone or with the battery permanently installed.
Charge the battery up to full charge and then disconnect the battery from the device and keep it safely for when you next need to use the laptop/notebook/netbook on the move (if the battery is stored for long periods it may require additional recharging to both maintain the battery's condition and to keep it fully charged because low level power dissipation takes place in a disconnected battery). Then connect the device to the mains electricity without the battery and continue using it like that.
If the laptop/notebook/netbook is mainly used in a single permanent indoor location, then charging has to stop when the battery has reached 100% full charge and should only be resumed when the device gives a low battery charge warning.
It is also important not to let rechargeable batteries drain completely by ignoring the low battery charge warming and continuing to use the device until the battery runs out of charge and the device powers down suddenly. Sudden shutdowns like this are neither good for the battery nor the device and can shorten the lifespan of both.
Continuing to charge any rechargeable battery when it has already been fully charged damages and shortens the life of the battery. It can even damage the internal Power Management System of the device if done over a sustained period of time and/or for prolonged periods of time.
When your notebook only shows 75% as the maximum charging level, this is an indication that one or more (probably two) of the individual cells that make up the battery are fully depleted, damaged and probably no longer capable of storing a charge, for the reasons given above. You should stop charging this battery after it has reached 75%, otherwise more cells are likely to become damaged and so on until the entire battery is dead, unresponsive and useless.
Nov 20, 2011 | Acer Aspire One PC Notebook
Hello , I have acer aspire one 751, with win
OK, it sounds like the acer aspire one 751 has a bad battery that will need to be replaced. It is not taking a charge, so it is not detected even though it is connected to the laptop. The 'plugged in' message shows that the charger is connected and detected by the computer, but the battery is 'not charging' due to the bad cells.
Good luck on finding a replacement battery.
Dec 18, 2010 | Acer Computers & Internet
Acer aspire one battery not charging to 100% despite prolonged periods of charging
You have one or more dead cells. What happens is after a long period of time, electrical "fingers" grow across the plates of the cells, caused by the chemical reactions within the cells, and short circuit each cell in time. Putting a high current for a very short period of time through the battery, can reform the dead cells, but not usually for long.
Fit a new battery.
Oct 31, 2010 | Acer Computers & Internet
Our acer aspire 4736 battery lasts only for 15 min how do i solve this problem
how old is your laptop? if it is more than 2 years and you regularly charge discharge your battary, then its time to get a new battery. but now on, run your laptop on power only. it will prolong the battary life.
Sep 07, 2010 | Computers & Internet
Hi my acer aspire one charg only 79 % not 100% plz solve my problam
Remove the Battery
Sometimes the battery may get dislodged from its chamber due to some movement. This will inadvertently mean that laptop battery will not charge since it is not placed in the right position. Removing the battery and then placing it back in its place properly will show you if this was the reason why the laptop battery was not charging when plugged in. There are a number of connectors that work in tandem when the battery is being charged, and the displacement of even one of these components leads to the laptop battery not charging problem.
Refresh the Battery
Some manufacturers of laptops provide the option of refreshing the battery after it has been used for a period of time, in order to enhance and prolong its life. Read the manual that you received with your laptop and check if this service is available to you. This can be carried out by entering the BIOS or the CMOS setup, and the instructions for this will also be provided in the manual for your laptop.
Replace the Battery
In all likelihood, the reason why yours Acer Aspire One is not charging is that the battery has worn out. Like all electronic components, the laptop battery is also culpable to deterioration over time, and due to this it may not be getting charged at all. In such a situation, you have no choice but to simply replace the battery with a new one. This will solve all your problems and also give your laptop a new lease of life. You may wish to know more about how batteries work.
Aug 18, 2010 | Acer Aspire One PC Notebook
My acer 5735 won't hold a charge. Seems to charge (green light)
if it doesnt hold a charge its degraded and will need to be replaced . people dont realise that keeping a laptop plugged in damages the battery
Jan 10, 2010 | Acer Aspire 5735 Notebook
Help on extending the battery life of my acer aspire one!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
The only solution is a new battery.
Dec 26, 2009 | Acer Aspire One PC Notebook
After charging baterry doesn't hold charge more than 20 minutes.
depending how old your laptop is the batter is on its last leg. What happens is if you leave your laptop plugged in all the time, the batter gets overcharged and begins to die. For the next battery you acquire remember to charge it for its required time then drain it out by using the laptop. This will prolong the life of the battery.
May 25, 2009 | Acer Aspire 5100-5033 Notebook
Acer Aspire One D250 (99802378332) Netbook Logo
184 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
