Question about Hoover F7431-900 SteamVac Vacuum
Hoover Steam Vac Dual Tank Bottom Valve Spring Assembly Part Needed
There appears to be what I would call a valve/spring part(on the bottom of the combination water/solution tank) that has completely come out leaving a hole. I have this part but it will not reattach properly. I'm not sure if a seal is somehow missing that could have been there previously and is now missing? This results in water pouring out and rendering the use of this product inoperable. I know I can purchase an entire new tank; however, all I need is to know what I need to do with what I have and purchase only what I need rather than incur the cost of the entire tank unit. Thanking anyone in advance for their reply.
  • troot7 Aug 23, 2008
    I'm having the same problem - somehow the valve and spring stayed in the bottom of the tank before, but I don't know how, since I never really looked at it. Help!
It appears that there is a problem with the o-ring design. The o-ring should maintain a certain OD dimension and keep the spring assembly from pulling throught the hole. I am trying to find the service manual to locate the o-ring part number but have had little luck so far. I think that hoover should have maybe used a higher derometer material.
Posted on Sep 07, 2008
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac F6210 solution tank spring repair
Hi there. The spring on the clean water tank cannot be replaced. A replacement tank would be needed. Follow the link to order a replacement clean water tank for your cleaner. Search Results
The clean water tank does not include the handle but your original handle will fit the replacement tank as well. Hope this was helpful!
Jun 19, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover agility steam vac F6210 solution tank repair
Hello! The valve assembly is not replaceable on the F6210. We recommend replacing the solution tank part number 90001091, can be purchased online or through a local service center. Hope this was helpful!
Jun 19, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
I have a Hoover Steam Vac Dual Model # F7426-900. The nozzle and spring from the bottom of the soap dispenser popped out. Can this be fixed?
You will need a new valve assembly. ( part # 43513014, msrp $3.62 ) Place the rubber seal in first, then wet the valve and push it in with your thumb.
Jun 24, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a Hoover V2 Steam Vac widepath and the
This is a notorious problem with the Hoover V2 SteamVac's. In fact the tank design by Hoover on your SteamVac was so bad, that Hoover redesigned this tank almost immediately due to the numerous problems customers were having.
For your particular problem, you really have two options. The first option is putting a bandaid over the problem, but will still fix it. We sell the entire gasket assembly on the bottom of the detergent tank as a replacement part. Unfortunately it's sold together with the seal, spring, and valve together as an assembly;
You also may wish to fix the problem completely by replacing the entire clean water solution tank. Hoover has redesigned this tank, and the new one I don't see near the amount of problems that I do on the older style tanks. The plastic is much more sturdy, and less prone to having the gasket and valve issues that the old tanks do. It's important to point out that the new tank does not come with the handle. You'll need to remove the handle from your old tank if you buy a new tank assembly complete. Rest assured that if you do purchase any part from GoVacuum, you'll have 60 days to return it for a full refund, just in case the repair doesn't work. Not only do we not deduct restocking fees or shipping charges, but we also include a return label with every order that you may use to return any item to us, and we'll even pay for your return shipping!
Here's the Hoover SteamVac V2 Clean Water Solution Tank, Part 12002549
If you'd like us to do a repair photograph series on this repair of the valve and gasket assembly, please just request a repair clarification here on Fixya, and we'll be happy to do so. If you found this helpful, please be sure to rate the review as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of the repair.
Thank you so much,
Chris J.
Mar 23, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The valve at the bottom of the tank has a valve stem and spring, you may have to replace the spring maybe.
Go to for a picture.
Jul 13, 2008 | Hoover Vacuums
I have a Hoover Steam Vac V2, model #F7430-900. The spring loaded valve on the soap dispenser needs replacing -is this possible or do I have to get the entire tank. Thanks
Hoover Steam Vac V2, Model #F7430-900
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You cannot replace the spring loaded value on the soap dispenser – it is a whole assembly and would need to replace the entire tank, you can buy them new or sometimes a local vacuum dealer may have a good used one on hand and that would work as well – check the yellow pages for a local vacuum dealer or Hoover dealer for replacement of the part. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Vacuums
Valve Stem Assembly for Hoover Steam Vac
Put the rubber seal on the bucket first, then put the spring on the valve stem, slip into the hard collar, then push it into the opening in the seal, it will snap into place.
Dec 29, 2007 | Vacuums
Valve stem assembly
Vacuums Logo
90 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
