HI I HAVE OMNI TV SET I HAVE UNIVERSAL REMOTE UBL JUST WONDERING WOULD I BE ABLE TO GET A CODE THANKS
SOURCE: ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
Posted on Dec 07, 2007
SOURCE: code numbers to set up iLo tv
Checked on line for any code there was that someone used for iLo t.v.'s, found two codes on your site that someone had used & used those & one of them worked. Thanks again!
Posted on Apr 02, 2008
  • 21 Answers
SOURCE: Programing Code for RCA Universal Remote Control
It does not have any code.
Posted on Oct 22, 2008
SOURCE: TV remote code for Norcent lt2720
I'm pretty ignorant on a lot of this stuff, so no bets here, but I did get the Dish network remote to power a Norcent tv on and off by using the code posted in the manual for an NCT television. Good luck.
Posted on Jan 18, 2009
  • 686 Answers
SOURCE: codes for universal remote foe ilo tv
0198 1070 1024 1023 0146 0189 1139
Posted on Feb 26, 2009
I have jVC tv and a omni universal re mote control what the codes for the tv.
0286,0288.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 24, 2014 | Televison & Video
Code number for tv NEC tv unit
HI Richard
Could you provide us the model number for the TV , so that we can give you the remote code.
Thanks
Proton
Aug 04, 2008 | Televison & Video
BLUESKY
Hi, each TV has its own specific set of codes it uses. But regarding universal remotes and programming them they are all different. universal remote manufactured by "one for all" might have the working set of codes for your TV under code 1234, and universal remote "RCA" might have the working code for your TV under 987. so the code depends on the universal remote you are using.
So we need to know the brand and model number of your universal remote you are programming to find you the correct code. And even if we do find the correct remote and manual for your universal, there is a big possibility that the universal remote will still not work.
Nov 30, 2012 | Televison & Video
Want to reset the v-chip on my 2001orion tv model # 1933
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Aug 12, 2012 | Televison & Video
Need tv code numbers for gemini universal tv remote so i canprogram to my magnavox tv set
Code for your Gemini universal remoet to progrmme your magnavox TV are
080,120,130,190,270,300,0054, 0706, 0030, 1454, 1254
Thanx
Aug 05, 2010 | Gemini 1 Device Universal Television...
Setting up a Harmony 659 universal remote without original remote
Hi. Chances are the commands for your TV are already in the Harmony database. All you would need to do is add the TV to your remote and it should work.
1. In the software, click 'Add Device.'
2. Enter in the model number, etc.
3. Update the remote
May 07, 2010 | Logitech HARMONY 659 Remote Control
Hi i have a universal remote an no manual for it. One for all is the brand URC-3415 is the serial number I need code for Rowa tv
hi
here is the remote support site
http://www.oneforall.com/us_US/support
here is your model manual with rowa tv codes
http://www.oneforall.com/uploads/support/1dda578b9a124e8e63bebd935e52b49a.pdf
good luck
Nov 05, 2009 | One For All URC-3021 Remote Control
Hi i have a giant tv remote lost the code for the rca tv the remote is an Omni tech could you help
yes i can... the codes are 000,003,004,005,007,009,011,015,048,082,092,094,096,098,101,102,103,107,113,125,129,167,179,187,188,191,and 194. ok you first turn on the tv. then hold down on the code search button for 3 sec. or untill the led stays on. try each 3 digit code untill it works. some codes my turn off tv but wont change channels. try another code untill it all works for you....... hope this helps........ thanks eddy
Jan 02, 2009 | Brookstone 538744 Remote Control
No remote will work on TV
i can suggest to try again with an original remote , sometime happens the universal remote is not able to match some brand of tv
may be also a little possibility the receiver on tv   has a problem
but normally that is not easy it happens - delfo
Mar 19, 2008 | JVC AV-36050 TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
