Question about Sanyo PLC-SU50 Multimedia Projector
Our projector keeps turning itself off!! - Sanyo PLC-SU50 Multimedia Projector
  • Sanyo Master
  • 17,130 Answers
Please check that the plug is tight to the outlet, the fan is working, there is no clogging of the filter as the reduced cooling will result in the temperature rising thereby the temperature sensor will cut off the lamp to save from failure.
finally if the lamp has worked many hours it can be weak and so heats up more. If so the lamp must be changed. try to swap and confirm. Use an extra fan to check with the cooling.
Posted on Apr 11, 2011
My viewsonic cine1000 shuts itself off after about 15 -20 min of playing. The bulb has about 500 hours on it. Why does it keep shutting itself down? It doesn't turn itself to standby either, the...
Make sure the PC itself is not going into a power saving or screen saver mode...this is the most common issue when playing completely automated presentations or movies.
Normally, I suggest turning off all power saving functions in the PC or Laptop, and disabling the screen saver all together.
Jun 20, 2011 | ViewSonic Cine1000 Multimedia Projector
My proxima dx2 turns off by itself ~5 minutes after it is turned on. Why
try resetting to factory default. does the fan and light turn off at the same time? you have a power supply problem. if the fans stay on when the lamp is off, you need to clean the dust out of your projector because it's overheating. dust keeps in the heat that the projector is trying to expell. blow it out with canned air. if it still does that, replace the lamp.
Dec 03, 2009 | InFocus Office Equipment & Supplies
Christie error message "Lamp Interlock Fault"
the switch itself may be broken. check continuity.
May 14, 2009 | Christie Roadster X9 Multimedia Projector
Projector keeps turn itself off
I have a Dell MP2300 with a bad power supply. Everything else is in excellent working condition. the bulb is less than a year old and has less than 500 hours on it. My asking prices are:
1. WITHOUT BULB: $50 shipping
2. WITH BULB: $150 plus shipping .
If you are interested, please contact me. I will also consider offers.
JJ
Bethesda MD - 301-588-7222
Jan 09, 2009 | Dell 2300MP Multimedia Projector
Cleaning my air filters
air flter is on the left of the projector; just click the plastic cover off and then vacuum the filter: if this doesn
Dec 10, 2008 | Hitachi CP-X275 Multimedia Projector
My in1 projecter keeps turning itself off
if the lamp has 2000 hors on it, it needs replacing. go into the menu and find out how many lamp hours are used. it could be the lamp and it could be the ballast.
Nov 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
Sony VPL-DS100
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
Jul 06, 2008 | Sony VPL-DS100 Multimedia Projector
Sanyo Pro xtra projector - warning light
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Feb 08, 2008 | Sanyo PLC XU33 Multimedia Projector
Sanyo PLC-SU50 Multimedia Projector Logo
228 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
