Question about Ovens
Just after a use it for 3 times today in the morning , the 4th one did not heat up . but still light and plate are working
Burnt some food yest in grill and is not working today. wouldnt turn on straight away so i left it till this morning but still not heating up. oven is working perfectly fine. could the heating element for...
if the temp light or indicator light for the grill is on then i'm tempted to say that it is the element but checking for resistance is the only sure way to know..
Dec 22, 2009 | Zanussi ZBF360 Electric Single Oven
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
All four burners click at the same time; Sometimes will not light
hey mate i have had this problem with my oven, they get moisture in them. Turn it off at the power point for a few hours or before you go to bed and turn it back on the next morning and it should be fine. that should get the moisture out. hope this helps. Keeno in OZ
Mar 19, 2009 | GE Ovens
My oven will not heat up at all.
make sure your cooking timer is on manual....
Feb 01, 2009 | Whirlpool RBS305PD Electric Single Oven
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
Oven not heating up.
fault is the circular element found the fan. take back plate off inside oven and element is exposed. often but not always, you can see the damage to the element. element is easy to replace - usually held in by 2 - 7mm nuts on posts from the element base plate
Jul 06, 2008 | Stoves Ovens
Ovens Logo
12 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
