Once you turn on aircon with fan with high speed, the air blown doesn't get cold even after a while. The fan makes some wierd high pitch sound as if like metal against each other. The fan stops once in a while and makes that same sound once it start turning again. This goes cyclic through out the time it is turned on but not cooling the air from the aircon.
  • 17,130 Answers
Your AC needs a good overhauling as the fan seems struck on the bearings or the blades are rubbing the sides. Also the compressor fails to cool as there can be low gas, low pumping pressure or a blocked condenser.
You need to remove clean the coils and lubricate the fan to be set back. Check the capacitor to the fan and compressor as a low value will reduce the speed and so reduce pumping pressure.
Posted on Apr 11, 2011
Split type aircon
It sounds to me that the air con is on auto fan, as the room gets hotter or colder the fan will slow down and stop. keep the fan on low,med or high fan speed
Apr 02, 2014 | Carrier Heating & Cooling
I have a shenbao mennelium aircon its gets cool after i turn the unit on but after 10-15 min it stops blowing cold air i have to shut the unit off and then back on to get cold air and also the compressor...
Check the fan,to make sure it is really turning fast on the high mode with ac on,not just fan.It sounds like the fan is slowing down,and not cooling the condenser,therefore cause the head pressure to rise,and producing warm air.The fan motor would have to be replaced to fix the problem if this is the case.
Apr 16, 2012 | Heating & Cooling
Air is not cold
there could be a number of reasons. 1 would be thre is no more freon on your AC unit. the other is that the capacitor for the compressor is already busted. Have this fixed by your local aircon specialist.
May 24, 2010 | Sanyo 18KS52 Air Conditioner
Too hot little cold
Very possible your condenser is extreemly dirty and is turning off on a high pressure cutout. suggest you clean out condenser with compressed air. Brushing is not enough. also, check if condenser fan(at the compressor) is working.
May 21, 2010 | LG Heat cool Window Air Conditioner
Refrigerator making a high pitch vibrating sound
Sounds like the fan from the freezer that blows the cold air into the refrigerator is noisy. It either needs replacement, or lubrication. Good Luck, I hope this helped Please rate me, Thanks
Jan 12, 2010 | Refrigerators
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
