I select a programme and then press the start button, the door locks but the start light flashes, and nothing happens
My 1400 spin whirpool washer has stopped working. we have tried checking draining, power supply, setting programmes will only drain then stops. Is there a reset programme?
Posted on Apr 11, 2011
  • Washing Mach... Master
  • 17,130 Answers
When the program is pressed to start then the inlet valve must open and allow the water to come to the drum. if this is not happening then check the voltage to the inlet valve, if there is no voltage then the program controller is not outputting and so defective.
If not the inlet filter/valve is clogged and will need a back flush .
Testimonial: "Thanks for that. I have ordered a new one "
  • Naas
    Naas Oct 13, 2015
    How do you back flush the inlet valve?
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
Hoover Nextra HNWF 3135 Door Not Locking
1) since you do not have any error code, because you do not mentione, we must shure you have problem with the switch door, test for open or defective and replace, Test the wires loose, or broken wires.
God bless you
Jun 28, 2012 | Washing Machines
Zanussi TCE 7276W Condensor Dryer - no red lights but won't go!
Hello, have you cleaned the condensor stack just recently if so check that the stack etc is fitted correctly and the door is closed fully.
Hope this helps.
May 14, 2010 | Dryers
Has the condenser been cleaned lately if it is not put back in correctly then sometimes the micro switch on the door does not click in,check this door where the condenser sits.
Hope this helps.
Mar 25, 2010 | Dryers
Power light is on but nothing happens - indesit iwme12
If the door does not lock at this point it probably needs door lock replacing
Sep 05, 2009 | Washing Machines
Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Jun 07, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi wj1054 front load
Check the water level pressure chamber for a partial blockage, this can cause all sorts of problems.
Apr 07, 2008 | Zanussi F1045W Front Load Washer
Washing Machines Logo
572 people viewed this question
Top Washing Machines Experts
