Question about GE E1030 Digital Camera
Hi have got this camera and i have puit in new batteries but it is still coming up batteries exhausted eben those they are new and the batteries work on other camera
I have changed the batterys with new sets but it says battery exhausted.
hi there during replacing the battery go in setting and select the battery type from there. If there is no option then reset the camera setting and then use a new fully home based charged battery . After that let me know the result.
Jan 13, 2011 | General Electric A735 Digital Camera
Sony DSC W30 digital camera, lens unit problem
Hi!
If you're sure you didn't damage the lens flat cable which connect to the motherboard, the focus of the lens unit you bought on ebay doesn't work. You can simply replace the back part (with focus) of the new lens unit with your old one. It requires soldering.
Tom
Mar 06, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Nikon L100 shows battery exhausted error message after installing new batteries. Unable to perform any operations on camera
That's the bug in Nokin L100, update the firmware version from 1.0 to 1.1, this will solve the battery exhaust problem. Firmware version 1.0 has only 2 battery (Alkaline and Lethium) option where as Firmware version 1.1 has Nickle battery also. But, to update the firmware you need to have EH-67 AC Adapter to give power to the camera.
Jan 24, 2010 | Nikon COOLPIX L100 Digital Camera
Camera shows "exhausted batteries" with new ones.
i have this camera and i had the same problem
everytime i put in new batteries like 5 seconds later the battery was exhusted i tried cheap and expensive batteries but nothing seemed to work
i would recomend rechargealbe batteries because they last longer but if you prefer one-time use batteries you should change they battery type in the menu/ setup
hope this helps!! good luck
Jun 03, 2009 | Nikon COOLPIX L18 Digital Camera
Battery exhausted
i have a nikon 7600 when ever i turn my camera on it says battery exhausted and turns off ny its self. so i tried buying new batteries and it still did the same thing what do i do
Jul 28, 2008 | Nikon Coolpix 3200 Digital Camera
Battery Problem
I just had this problem today myself, and looked everywhere online for a solution. I changed the batteries (to Panasonic), and it didn't help. But i tried different batteries (Energizers) and the camera started working again.
Aug 31, 2007 | Nikon Coolpix 3200 Digital Camera
Battery error
Clean the battery contacts in the top and bottom of camera- Come back if no go
Aug 17, 2007 | Nikon Coolpix 4600 Digital Camera
Status LED just blinking the whole time when switched on
Samsung digimax Technical support may have an idea. Is the manual still available - to format the memory? I guess however at the end of the day you /He will be looking for that new camera
Jun 26, 2007 | Samsung Digimax 401 Digital Camera
Status LED just blinking the whole when switched on
I have lost all confidence in this model camera. If you managed to take at least 500 pics - consider yourself lucky. Even the experts are baffled by this problem. Time for a new camera BUT not a Samsung I"d say.
GE E1030 Digital Camera Logo
126 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Are you a GE Camera Expert? Answer questions, earn points and help others
