There's paper in the printer tray but it doesn't pick it up gives a message that its out of paper ?
    Genius:
  • 2,432 Answers
Unplug your printer then try to vacuum and clean inside dust can cause error. make sure no foreign material inside that blocks the mechanical part especially during start up so that it works properly.
Posted on Apr 11, 2011
I have an 3260dn laser printer and the "Paper Tray Empty" light is on and will not reset, even when I fill the paper tray
The problem could be caused by the pick up tires on your printer. If it doesn't pick, I suggest you call Lexmark Technical Support.
Jul 26, 2011 | Lexmark E260dn Laser Printer
Printer will give a message of paper jam appears to be unable to pick up paper from tray . Can I fix this with a new paper tray if so where do I get one ? Or is there a better solution
I have worked on many a printer and I have yet to find one that when it says there is a paper jam is lying. You may need to take the printer apart to find the jam. It can be the tiniest of paper and can be located in an area that is difficult to find without taking the printer apart.
It also may be that the rollers that pick up the paper are bad. These should be easily replaced. Check the manual or help support online with the printer manufacturer for replacement parts. Typically the paper tray does not have the rollers so replacing the tray may not help you.
Apr 27, 2011 | Brother HL-4040CN Laser Printer
Message : load paper. It's trying to pick up a paper from the tray. Kept failing giving a same message over and over
First remove toner crg., and check if the pick up roller is in his place on axis above paper. Grey half round roller. Clean it also.
Jul 01, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
HP Laserjet 2420- Late Paper Jam
1) Your paper tray may be too full, makes it heavy to lift and not enough pressure for the pick up roller.
2) Pick up roller is slippery, wipe it clean with alcohol to make it abbrasive.
Apr 15, 2008 | HP LaserJet 2420 Printer
Paper Jam Error Message
I would try to clean the tires with alcohol, it's probably trying to pick up the other sheet but is slipping.
take out the tray and look inside for the pick-up and seperation tires.
Oct 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
