Question about AEG Lavamat 88840 Front Load Washer
The wash cycle works, the pump wprks, but the spin will not. There is a high pitched buzz and our overload switch throws out when it hits the spin cycle. I have taken the motor out and the brushes look fine. The bearings seem noisy and should probably be replaced but it still spins freely and smoothly. The washing machine is about 15 years old.
  • jterrey Apr 11, 2011
    Thanks Ginko. The machine is an AEG Lavamat 538-W frontloader but the website wouldn't accept that and I had to tick something
    The pump works and seems to empty everything, although having read your spin link I must say the contact on the sensor at the base at back of the drum looks a bit corroded. The main motor drives the drum for a wash but fails when the spin comes on. Would worn brushes make the main motor fail under a load?
  • jterrey Apr 13, 2011
    Thanks Ginko, the advice was useful. I can't see any obvious shorts so I'll take the motor in for testing. If the motor's OK I'll look at replacing the CCU or the MCU
  • AEG Master
  • 19,396 Answers
Hi.
If the switch trips off, that means that there is an abnormal power draw, which means a short. If the pump is humming you probably have a defective pump motor. The fact that brushes look OK does not exclude that the motor windings are internally shorting. Remove the pump and read Ohms on pump motor contacts. a shorted motor will read zero Ohms. The definitive test will be done by a tech energizing the motor directly (jumping it), then connecting power. That will probably trip the breaker, telling the tech that the motor must be replaced. For safety reasons I suggest only carrying tests that can be done with power off. After 15 years the pump is probably gone.
For general No-Spin issues, see this: If you have no spin...
In your case the situation is different, I think you have a defective pump motor. If problem is not the motor, then it is either wiring harness or timer (uncommon). In that case the breaker trips immediately before pump starting. Check also that problem is not main drive motor. It may be shorting when spin cycle starts. In that case the pump will drain before going to spin.
Regards.
Ginko
Posted on Apr 11, 2011
  • Ginko
    Ginko Apr 11, 2011
    Hi.
    Worn carbon brushes is not necessarily the cause of the problem , but that tells you that the drive motor is old. The problem is not the carbon brushes. Since the variable speed motor is turning at slow speed, the brushes are still working. The brushes can be tested ensuring that they are touching the commutator (read Ohms) , but in any case when brushes are too worn motor will simply not spin.
    The short may be given by the motor winding shorting. When that happens the whole motor must be replaced (re-winding is not worth and it is not done anymore).
    More commonly the short may occur in the CCU (main control board) or MCU (motor control unit). One of the two boards can short when energizing the variable speed motor for spin part of the cycle. The motor control unit (if present) is in a sealed module inside the washer. MCU connects to CCU and to motor. Since boards are difficult to test, look if there is trace of short in any of the two modules (burnt spots - component melting- smell). If there is none, go back to motor and test it for shorts using a growler: Armature Test ( it can also be energized jumping it at high speed). Check the boards first.
Machine was overloaded and now the spin cycle will not work
hum check the belt if applicable, the door switch just in case co incidence plays out here, also may have a bad clutch or motor coupler, or worse case problem ur tranny. are u saying it still washes though? overload should not throw out ur spin cycle but can damage ur clutch and tranny? lest u have a digital electronic board on this machine and they are know to go bonkers. some machines actually have a auto fixit for overload or unbalanced issues.
Feb 18, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
Our Frigidaire Front load washer FWTR445RF50, washes fine.But the water does not drain out after the wash and the spin cycle does not work. At the spin cycle, the washer acts like the door is not fully...
it won't spin unless the water is drained out.a bad door switch could cause this and is the easiest part to change,and if it's buzzing and it's coming from the switch i'd say you have a bad door switch,also on these machines they had problems with the door hinge the door would sag down and when you go to close it it would hit the bottom of the switch instead of the strike going in the middle of the switch and crack or break the switch,if you think your door is doing this,replace the door switch and when you go to close the door lift up on it when closing so it closes better.one more thing it's not draining so if the door switch doesn't totally fix it check the drain pump and the hose that goes from the tub to pump,it might have a coin catch in it that can get clogged stopping the pump from draining or a bad pump but i would change out the door switch first it could fix your problem before you start getting into the pump,much easier to replace and i've changed a few door switches on these washers,good luck.the door switch part number is 131763256.go here put your model number in go to where it says wash cab,top look at part number 8 this is your door lock,it gives a different number but for some reason sears hasn't updated the site with the newest numbers but the number i gave you is the newest number for the part
https://www.searspartsdirect.com/model-number/FWTR445RFS0/1428/0153200.html?searchType=modelSearch&q=FWTR445RF50&searchTerm=FWTR445RF50
Jan 08, 2018 | Frigidaire FWTR445R
Won't go through spin cycle
is the water being pumped ot f the drum. if the pump is not working it will not spin . put the washer on a drain and see if you can hear a buzzing if there is no buzzing i would take a look at your pump
Jun 26, 2009 | Kenmore Washing Machines
Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Jun 17, 2009 | Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
AEG Lavamat 88840 Front Load Washer Logo
319 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
