Receivers
Problem for Receivers
Generic problem for all Receivers
Blown fuses in a Pioneer RX-570
By sabackdoc on Aug 07, 2008
I took your advice and found the fuse was blown. I got a 6.3A 250V slow blow fuse from Radio Shack. However when I plug the unit back in it blows the fuse. What could be wrong and is it an easy fix or should I take it to a repair shop. I think the original problem was caused by a power surge as the power had gone out earlier in the day due to a thunder storm.
Solution #1
posted on Aug 07, 2008
Somewhat Helpful)
robotek
Rank: Guru
Rating: 91%, 1181 votes
Hi sabackdoc
Ok, it is probably not an easy fix for a layman. It may have blown output transistors, or power supply failure. As to whether it is economic depends on what has actually failed. But if it is output transistors failed, be prepared for $130 to $170 to fix it. Probably not worth it. They are a little temperamental to fix, and I recall repairing a number of them under warranty when the were new for blown output stages. It is worth getting an estimate from someone near to you. Try and use a Pioneer agent as they have experience and access to spares. Sorry this is not a fix for you, but I hope that it turns out ok for you. :)
regards
Robotek
Was this helpful?
Yes
No
Popular Solutions for Receivers
Questions and Unsolved Problems for Receivers
Answer
I have an aiwa sterio receiver (AVS17) and it seems to be stuck in Eco(nomy) mode. Won't turn on but... (More)
Answer
how should i connect mi subwoofer it's not powered
Answer
nakamichi RE-1 left channel droped out any suggestions, worth repairing or getting a new... (More)
Answer
Hi, I was lucky to still get one of the Yamaha RX V463 AV Receiver, because they are being replaced... (More)
Answer
I have a Onkyo txsr705 reciever and the rear right channel has gone out.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Receivers Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
