Question about Sony Ericsson XPERIA X10 Cell Phone
I'm using SE X10i, my device will shut down and reboot suddenly. Sometime it just shut down and reboot again when i was just used for not more than 5 min. Please help me to solve this problem. it's annoying me.
5 Suggested Answers
SOURCE: malfunction of my mobile
dont show my sell phon wind screen and no show any i con i am verry sishart plz soulve it thank you .my no 03002512492 plz call me bak
Posted on May 20, 2008
Sebin
  • 712 Answers
SOURCE: I don't how to use
Please read each steps of your user manual carefully and in 2 days you will become the master of your phone.
Posted on Sep 09, 2010
vivsrulz
  • 91 Answers
SOURCE: dear sir,i am using sonyericsson xperia x10i.now
you must reset your phone. This will wipe all the contents of the memory
Posted on Feb 28, 2011
cyberprem
  • 166 Answers
SOURCE: i cant boot my xperia x8 after installing a custom rom
May be you have bricked up your phone. Try flashing your phone with ODIN. This will get you back to stock rom.
Posted on Nov 28, 2012
Sudden shut down
It's possible that this is a hardware failure or a power adapter failure. Try to reset the unit and reinstall it again. You can also check for firmware updates available online. Try to use other power adapter as well with the same specs with the original power adapter.
Jan 25, 2014 | Linksys Computers & Internet
Everytime i try to get on the internet i get connection error 80028EA1 and when i test my connection i get the ip address but not the internet connection and then the same connection error 80028EA1 shows...
Try the following a reboot can sometime fix a lot of different problems.
1. Shut down PC or PC's (ALL CONNECTED DEVICES)
2. Unplug Router/Access Points
3. Unplug Modem Wait Approximatly 2 Minutes
4. Plug in Modem wait 2 Minutes
5. Plug in Router/Access Points Wait 1 Minute
6. Restart/Reboot PC/Connected Devices.
More Information is needed for further Diagnosis! Thank You and Good Luck!!!
Jun 12, 2011 | Computers & Internet
How do i delete photos and all contacts
1. Download (from http://www.multiupload.com/37ZHSBAPQU) and unzip the file.
2. Read howto.txt and find your DeviceID in the registry and change the DeviceID.txt in step1 and step3 folders.
3. Now run step1.bat. This will update the phone firmware to R1EA018 S0-O1B.
4. After flashing, remove the battery and wait for 5 seconds.
5. Replace the battery and reboot the phone.
6. When phone is running again activate USB-Debugging.
7. Do a factory reset (recommended).
8. Then run step2.bat. A popup menu should appear.
9. Choose option 6.
10. The phone will reboot and flash. After an end and everything will be ok.
11. Now run step3.bat. This step will update the baseband X10i R2 (this is for X10i only).
12. After you finish this. The phone will restart.
13. Now run step4.bat. This will allow the root, and delete SE and Docomo Stuff from phone in addition to installing small apps.
Originally Posted: http://thetechjournal.com/electronics/mobile/steps-to-root-sony-ericsson-xperia-x10-phone.xhtml#ixzz15Vs9EnHN
Nov 17, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Xperia X10i. Only four months old and all of a sudden the battery will not charge. Not from the mains or with the usb cable. I have even ordered another battery to go along with the car charger that I...
Hello,why the phone is still shutting down is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
Take care.
Nov 16, 2010 | Sony Ericsson XPERIA X10 Cell Phone
I have installed Windows 7 on my Hp 6602au. It worked fine for a couple of months , till yesterday . Suddenly I lost audio from my laptop. The message near audio icon showed "No Audion Output Device...
Run a Windows Update, check to see if there is an updated audio driver, if not go into the device manager and remove all of the audio devices, reboot.
That should resolve your issue.
Let me know if it doesn't ;)
Oct 21, 2010 | HP Pavilion dv6000z Notebook
Blue screen
Simply change your Ram with new one.
Apr 08, 2009 | Computers & Internet
Satellite a135-s2386
Resetting your USB Controllers I'm going to assume that you're running XP (home or pro). Recently I had to refresh my USB ports. This is the sequence I used.
1. Right-click My Computer and select Properties
2. Click Hardware
3. Click Device Manager
4. Expand the Universal Serial Bus Controller
5. Right-click each USB device listed and select Uninstall
6. Click OK to confirm removal of each device
Note: Repeat steps 5 and 6 until all devices under UBS Controller are removed
7. Shut down computer.
CAUTION: Ensure that the Shut Down option is selected instead of Restart.
8. Wait a few seconds and turn computer on. When it reboots you will see "Windows has detected new or added hardware"
Note: You will have to insert your Windows CD, if prompted.
These steps will refresh the USB ports.
Added Notes: 1) If your mouse is a USB you will have to use the keyboard to shut down your computer. 2) It would be wise to unplug everything from your USB ports EXCEPT your mouse and/or keyboard before you restart the computer to avoid Windows replicating any printers, scanners, digi-cams, etc. Once Windows has refreshed your USB controllers and ports, shut down again. reconnect, and restart.
Good Luck
Sep 27, 2008 | Toshiba Satellite A135-S2386 Notebook
DELL D520 LAPTOP
Problem cause:
Do diagnose your Laptop try to change your battery or adapter if you have some backup device
Sep 22, 2008 | Dell Computers & Internet
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Wireless adapter in Acer 5610-4610 is gone suddenly
Few ideas here, but obviously these are tricky questions.
Uninstall all software related to the wireless NIC, and then uninstall the hardware in device manager. Shut the machine down. Turn the machine over and remove all the little doors and look to see if the wireless NIC is an add-in card you can access. If it is, remove the retaining screw and remove it. Reboot machine, let it boot up, log in, and then shut down again. Reinstall the wireless card and close everything up again. When you reboot, you *should* get the new hardware found message, if you do, install the with the latest drivers and then reboot, and then check to see if the device is working properly in device manager (no warning messages). If it does not recognize the hardware, check in device manager if it has somehow put it on the unknown device list. If it has, try installing the latest drivers manually for the device by using properties tabs on unknown device in device manager.
If the problem is that the devices won't recognise and install their own drivers, you have a different problem which HP or whomever should solve.
Note, too, that if the laptop included custom control software for wireless connectivity (Intel, I am looking in your direction), the card may not be recognized without it, so install that software again, too.
Hope this helps...
Nov 13, 2007 | Acer Aspire 5610-4648 Notebook
Sony Ericsson XPERIA X10 Cell Phone Logo
98 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
