My desktop computer shuts down automatically after using 1 hour. What may be the problem?
  • 17,129 Answers
Please and see if the processor fan is ventillating to the processor and so there is no heat build up to shut down the thermal switch. If there is dust use a good blower an brush to clean , make sure the fan works. Also the fan on the SMPS unit also must work well.
Check on all the connectors, press them all down. check the mains power .
Finally check on the power options for any changes or settings for shut down./ hibernate or sleep mode
Posted on Apr 11, 2011
My comuter automatic shutdown everytime i used for an hour
I suspect your computer is overheating and thats why it shuts down. Remove the fan from the processor and hoover out the heat sink and clean the blades of the fan too. make sure that any case fans you have are cleaned and working too.
Aug 28, 2011 | Computers & Internet
Tip
Automatically Close Programs at Shutdown
When you shut down Windows, if you have any programs running you'll get a message box warning you that a program is still running. You then have to close the program and tell XP again to shut down. It's a fairly pointless warning—better yet would be if XP automatically killed the programs without issuing the warning. That way, you wouldn't get error messages and wouldn't have to close each individual application before shutting down your computer.
To have XP automatically close programs at shutdown, run the Registry Editor and go to HKEY_CURRENT_USER\Control Panel\Desktop. Edit the AutoEndTasks key so that is has a value of 1. If the key doesn't exist, create it as a DWORD value and give it the value of 1. To disable it, either delete the key, or set the value to 0.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
When i restart the system don't turn on again
something may be wrong with the power supply. i have a computer where the power supply is faulty and it used to shut down automatically after 1 hour. nowadays, it shuts down more frequently, whenever restarted, it will not come up again. i have to wait for sometime so that power-supply can cool down and i can start. -Nitesh Kumar Anand
Apr 16, 2010 | Mercury P4VM800M7 Motherboard
I have a compaq computer that works great for 1 hour the shuts do
Is it shuting down? Or just instantly going off.
If it is shutting down, adjust the power settings.
  • Control Panel
  • Power Options
  • Make sure the scheme you want is selected. For a desktop it should be Home/Office or Always on.
  • Make sure that System Standby and Hibernate (if available) are set to the length you want.
Mar 13, 2010 | Compaq Presario 5000 PC Desktop
I have a Compac Presario, running VISTA. When
simply disable the automatic update service by following these steps.....
start | run | services.msc | automatic update
stop ...and disable it...click ok
and close the service manager....
then try to shutdown the machine ....
Dec 30, 2009 | Computers & Internet
I have a Acer desktop. after working for one hour it shuts down automaticlally. please help me.
Please check your Laptop Processor fan, if the fan stops working then the Processor got heat and system automatically shutdown or restarts
Dec 01, 2009 | Acer Computers & Internet
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
Automatic one hour shut down
Hi there.
Click on the start menu and go to the control panel, select power options and there you can set the PC to never shut down.
Good luck and thanks for using FixYa!!
May 13, 2009 | Compaq Presario 5000 PC Desktop
Computer will not shut down
right click your desktop go down to properties and click on it. then go to the screen saver tab and select power. then set the times there and hit APPLY then Hit ok.
Jan 27, 2009 | Computers & Internet
My system shuts down after 1 hour
First you do a reinstallation of ur chipset driver, then try setting a screen saver...
Mar 21, 2008 | Dell Dimension 4500 PC Desktop
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
