My machine keeps displaying a E9 fault, what should I do to repair this?
  • Washing Mach... Master
  • 17,130 Answers
You have not mentioned the make and model. Now the error is an indication of the fault or a protection indicated.
So remove power and plug in after making sure the door is shut - the door switch is checked to work.
If the error comes on , check on the power to the control panel, observe board for visible damage, check the inlet valve, check for working, check the drive motor, capacitor and drain pump/valve. Once confirmed that all these are working check for line break , if there was damaged done by rats/insects.
If none of these show an indicative fault then the program controller can be faulty.
Posted on Apr 11, 2011
My DAEWOO washing machine shows E9 error . How can I fix it.
Following is a summary of your problem:
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
You can check Daewoo Washing Machines' all Error Codes on the following link:
https://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/ Daewoo Washing Machine Error Fault Codes
Check the following link also:
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes
Feb 05, 2018 | Daewoo Washing Machines
E9 DISPLAYED IN WASHING MACHINE DAEOO MODEL DWF320LR WHAT IS THE PROBLEM
Jun 01, 2017 | Washing Machines
Fix for Janome error E9
take it to a repair shop the computer control is faulty
Apr 19, 2015 | Janome Sewing Machines
My NEC NW 652 washing machine is showing an E9 fault. When I hit the power button the E9 message appears?
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
Apr 25, 2014 | Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
My NEC NW 652 washing machine is showing an E9 fault. When i hit the power button the E9 message appears
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Jan 13, 2009 | Washing Machines
Error message E9
gebje,
error codes on pentax camera's are in the repair manual to help the technician find the problem faster. e9 is shutter failure and will need to be repaired.
May 10, 2008 | Pentax IQZoom EZY-R 35mm Point and Shoot...
NEC washing machine displays E9
fault code e9 relates to pressure sensor.
check connections or replce pressure sensor
Apr 29, 2008 | Washing Machines
Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Feb 15, 2008 | Microwave Ovens
Washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Feb 26, 2007 | Daewoo DW500M Top Load Washer
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
